Dealer option heater?
Sugar Land, TX
Website
www.shayahealth.com
Ok, so I pulled my '65 lpb out of the garage yesterday, and spent 6 hours cleaning out the interior (it was stored for 7 years in a barn). I pulled all the interior and used my pressure washer (2600 psi) with the 0 degree tip to clean it out. I just about threw up when I was washing out the crossmember that is under the seats. I ran water through it for about an hour, and I was still getting chunks of crap out (literally).
Anyway, when I first got the truck I posted up some pics, and Pimp said that he had seen the same DIY heater side vent on another 45 lpb. You can see the vent in the first pic.
The second pic is of the heater in the passenger foot well.
Since I had everything out yesterday I figure I'd pull the heater as well. On the back of the heater is the production date of Nov 18, 1964. :eek:
So, any chance that some dealer was putting these in? Just curious considering that it is about the same age as my truck, and they have been seen on other lpbs.
Tommy had the same side vent on his 45LV, it looks like its from a harware store, I dont think it was a dealer install.
heck the Jimiwag had some roof vent rubber seals for the steering shaft :rolleyes:
mantis said:
Ok, so any idea on the origin of these heaters?
I don't have the '66 dealer options here at work. This is '64 I think:
All of this is 45 wagon stuff but some of it should cross over.
The antifreeze shut off valve to my heater was Rainbird (home sprinkler systems) :rolleyes: . Also, the return line from the heater was cut off, and the hose had a rock stuck in it and clamped down on. At least I use Toyota parts... I took out the rock, and put in a motor mount bolt. :D
I beleive that this was a dealer option, My heater came to me taken apart, but that is what it might look like assembled.
dig dig dig!
holes/nipples might have been where a mirror was at some point.
mantis said:
Here is a close up of my vent.
I also have no idea what those two nipples (for lack of a better term) are in front of the vent.
This truck is a mystery wrapped in a conundrum wrapped in an enigma.
Picture of said rock :eek:
the Jimiwag had a piece of wood stuffed into part of the carb....... :rolleyes:
I second Pimp's theory about the mystery carraige bolts being from a mirror. Strange tho, as their close placement wouldn't give the mirror a lot of stability.
The only other thing I have seen mounted in that location has been a jerry can holder, and that would have required even wider spacing than a mirror.
I have dismantled about 6 rigs with those aftermarket heaters over the years. None of them had the external louvre like yours.
I've never seen one of those heaters
I have a 1965 SWB and owned a 65,67,68 LWB plus worked on a customers 1966 LWB and we all had the heaters
My 1962 FJ25 (tub) had a small square factory heater half the size of that one.
the only stock/optional Toyota heater for a fj25 or early 45 was this
hey..........thats mine ;)
