Just a quick explanation into how we used to find battery drains in the dealership, if the drain is intermittent then it is obviously harder to find. We used to use an amp clamp, this goes around the battery lead without any disconnections, then you would lock the vehicle but keep the bonnet open, you will have to hold bonnet switch down if one is fitted. Wait a few minutes after locking to ensure shutdown. Then read the amp clamp, you are looking for 100 mA (0.1A) Max, if any more then start pulling fuses untill drain disappears. Figure out what that fuse does then disconnect components to try and isolate fault. If the drain doesnt go after disconnecting fuses then you will need to disconnect the alternator, then the starter motor as these can cause a drain.
Most common cause is interior lights, radio including accessories, sat nav, water ingress, alternator. Anything that has a permanent supply is suspect but these are the most common. Disconnect any extras like tow bar electrics.
