Ok folks...semi real-time project question here. I’m pulling my first engine today. 1985 FJ60. Just pulling the motor by itself, not motor and trans. Searched threads and read up, but didn’t see any pics to confirm I was understanding exactly what they were saying.
Where I’m at currently: I’ve removed the hood, front fenders, radiator, front grill assembly in it’s entirety. Disconnected radiator lines, ground straps, and electrical lines that attach to the motor. Loosened motor mounts. Have the clutch inspection cover off.
From here?? .... attach lift chains to hooks, place jack to help support trans. Unbolt motor from transmission; is it the 4 big bolts I can see inside the clutch disc housing on the trans side threading in from rear to front (might be easier to remove front driveshaft to get to the bolt heads)? Start lifting and moving out; work slowly and watch for hang ups?
It was getting dark so I couldn’t really see, but where do I disconnect the clutch fork?
Withall the body stuff out of the way, a 2 ton crane, and load leveler, it should be pretty straightforward right?
What am I missing?
