geez, decided to remove a bad old tire myself to paint the (steel) rim. Probably 15 years old, never removed. Our kind of truck size. Left it in the sun. First had to struggle to break the bead, had to use a HiLift. Not as easy as I assumed. Was really glued on there. Then tried for a while to pry the bead over the lip with various improvised tools like crowbars. Nothing doing without it looking like I'd damage the rim first. Then decided to cut the bead with a recip saw to save time (!). No go. Busted a bimetal blade on the bead. Good I didn't try my pricier oscillating tool blade. Then decided to cut it through with a grinder disk. Even that was a struggle, thought the thing would burst in flames at times. But worked, if slowly. Finally ended up cutting the whole thing through to remove it.
I don't think I'd bank on being able to remove a biggish tire without proper tools and much more practice. Seems like a miracle to me that they are even able to do it in a shop with a machine without bending the lip or damaging the tire.
Tires are tough...
How d' you do it?
Tires are tough...
How d' you do it?
