lowenbrau said:In a spring under setup the drive shaft is the hypotenuse. As you lift the rig the distance from the t-case to the fixed spring hanger stays equal. (adjacent side) and the distance from the fixed hanger to the center pin of the spring pack stays the same (opposite side)
If opposite and adjacent do not change and but the angle between them is reduced, the hypotenuse must be reduced as well.
So as the springy thing arches, Mr slip yoke compresses?
