- Thread starter
- #21
Thanks! I love how it’s coming together.good lord its beautiful! Nice work!
-Rob
Thanks!Very clean...
What radiator is that and is it a double pass?
Thanks!
It’s the Ron Davis radiator. I believe it’s a double pass setup.
Thanks
-Rob
Thanks! I'm a fan of the simplified door cards as well. I have a set of the OneStone armrests, split between my LHD 80 Series and my RHD 62 Series. They work great!I dig those door cards- nice alternative to the usual US spec versions. I wish we had a better source for the factory style door pulls/armrests/window switch bezels in the aftermarket. It took me a while to find a decent set to make mine look nice.
I've got those same OneStone armrests modified to work with my factory door panels and love 'em!
The burning question is: If you pull the front shaft, & lock the center diff, will it do a big smoky burnout? ha ha ha
The headliner came from headlinermart.com. The pattern they used was almost spot on, I'd use them again.Maybe i missed it, but where did you get the new headliner? How long did it take to replace?
Finalized my Radius airbox installation last night. The airbox exit sits a lot lower than my previous setup, and ran it right through my radiator hose. I decided not to mess with any of that, and spaced the Radius airbox up a couple inches. No more clearance issues, and still plenty low enough for the hood.
Before:
After:
-Rob
The fender was cut before, using Radius's template. The airbox is more tilted than raised, the inlet from the snorkel still fit perfectly after relocating it. I ended up using the normal rear Radius mounting tabs, but moved them back to different existing holes in the fender (it lined up pretty well). The front mount is floating for now, but I'll make a small bracket to attach it to the fender.Did you cut the fender for the snorkel before or after raising the air box? I do think the Radius box could have the outlet putting more upwards than it does...
My intake is awfully close to an idler pulley and raising the Radius Airbox would help with clearance...
Thank you! It's coming out exactly how I wanted to build my dream 80!holy smokes, dream build into dream spec. Great job, very tasteful direction and mods.
Where did you source the doors?
