We are leaking a little oil around the driver side head cover gasket. I figured before I replace the head cover gasket I would just tighten the bolts. Can these be too tight? I only got them hand tight with two fingers on a 1/4" socket with the room allotted but I'm worried since they were all a little loose they may be too tight now to allow for expansion when the motor heats up. I also figured the head cover is probably cast so would crack easily if I over tightened s I took it easy. Thoughts?
