Cut and turn on site? (1 Viewer)
Yes, I've seen it done, however keep in mind once you're finished rotating the axel and have to weld up the axel tubes the amount of heat your axel seals will endure from welding, will probably cause them to fail prematurely.
This is the best time for new seals as you're already going in to the axel, do the labor once.
