Custom rear coils installed (1 Viewer)
little_joe
RDU, NC
Following on from my Radflo install thread - GX470: Radflo 2.5" with FJC coils - I ended up buying custom rear coils from Coil Spring Specialties in Kansas (Coil Spring Specialties).
Initially my request was based on the 2007 V8 4Runner Sport rear springs, and I specified a progressive rate with +3/4" lift, +15% additional spring rate, support for 200 lbs additional weight over the 4R specs. After thinking a bit while waiting for them to be made, I opted for +1" lift and 100 lb additional weight.
The arrived exactly when CSS said they would. I received them late Friday evening, and they were: +1" lift, 15% additional spring rate, 200 lbs additional weight. Sigh. After thinking it over, I decided to install them anyway. The applied finish on them did not blow me away compared to some of the shiny finishes on other coils, but the finish looked even and fully functional. Hey, it's a spring.
When I pulled one of the 2010 FJC TT rear coils and laid it next to the new coil, I thought - o crap. The new coil is slighly shorter, but has more wraps and appears to use slightly larger diameter steel. I don't (yet) have a caliper to measure, but will pick one up tomorrow to verify this.
Anyway, the fit is spot on, exact same dimensions so fitting to the MetalTech rear coil conversion base + 4R coil isolators was perfect.
Wrapping up the install, they netted exactly 1/2" lift on each side and it sits perfectly level side to side. And I didn't have to adjust the front any, which is what I was hoping for. We couldn't know the actual lift due to weight differences between the 4R and GX, but it worked out perfectly for me.
The ride? O my goodness, They are perfect! The ride is night and day compared to the FJC coils! At both slow and high speed (up to 80), with the rear 2.5" Radflos the rear is perfectly stable, soaking up the bumps with minimal bobbing. On my usual route where the FJC coils would allow the axle to hit the bumpstops, these springs soaked up the dips and humps and imperfections and did not hit the bumpstops.
Obviously they are new, so I'll follow up as I put some miles on them and get to work them on some trails and forest roads. But my initial impression is overwhelmingly positive.
Obligatory pics:
Very nice! I'll have to keep them in mind when I do my suspension overhaul.
JFYI with these springs, the rear of my GX is almost exactly 1" higher than stock at the Normal air suspension setting. The FJC springs netted 1/2", and now another 1/2" over that.
I figured I was taking a chance on these, but so far (3 days!) I couldn't be happier. I too am quite curious how they'll hold up over time.
Please post photos.
Looks like a nice option for a mild lift. Do you have pics of the rig with these custom springs? Also what is your overall vehicle height now?
I'm looking for a mild lift to make sure I can still fit in garage structures. Thanks!
@teejnut - I went with CSS springs too after Joe recommended them. Hop to my build thread for my write-up and pics (to come). I went the custom route for the same reasons you are considering them - urban living.
How long were your old FJ springs in for? How many miles on them? I have them in my GX now (TT edition) and I have no issues with hitting the bump stops or any other issues you mentioned. They are new though, so I'm wondering how long they'll stay that way.
@BlackCat I installed the FJC TT springs on June 15, 2015, had 89,850 mi on the GX. I pulled them in early November with 94.214 mi. Again mine were from a 2010 FJC TT, he ran them for right around ~40k mi and wheeled his FJC (incl loaded-down road trips to CO from NC to wheel).
I suspect the aftermarket springs you used might have a slightly more aggressive spring rate than stock, which would explain the lift you got when installing them. Yours do sound like a great (and inexpensive) option for those seeking a very mild lift, and if they last a few years they're only $75 to replace. :)
Ya, I guess time will tell!
Obligatory pics:
Are you still happy with these springs? If so, would you share the info you sent them to get the springs made?
I ended up going with a different spring to get more lift out of the rear end. The specs I used are in the 1st post of this thread.
Now I am even more curious as to what you went with because I was going to add another inch to what you posted.
I ended up going with Icon 2" springs in the rear. Wanted to go back to CSS, but these kinda fell in my lap and I couldn't say no. They're fine for my purposes.
same
