Very cool kit, sad to see the transmission controller is another $1k.
The conventional 60/80 series Cummins conversion went like this-
Cummins to straight up GM adapter $1150
4L80E $2000
Advance adapters splitacase adapter $600
Splitcase $200
drivelines reworked $600
4L80E controller $600+
Sorting out the transmission and t-case shifters (priceless)
Some kind of tachometer signal converter device $120
My rough math says that's $5K+ on top of what you give for an engine.
With these adapter kits you have-
Cummins to Landcruiser adapter $1250
Reworked Landcruiser converter (if you want to go all out) $250
Compushift controller $1100 or less if you actually call and talk to them.
That Looks like $2K less than the alternative just in parts.
How much is the labor saved by not needing to touch the transmission, deal with the transmission and transfer case shift linkage or reworking the tranny crossmember worth to you? These parts cut the scope of the conversion project in 1/2.
Sweet, now if someone made a motor mount kit instead of me having to fab 1
The numbers don't lie, now if I could find someone to do a swap on the east coast i would be golden
Hey hey!!!
Is that my adapter kit, I just bought???!!! hahaha
Looks great! Very happy with the finished product. Dustin was a champ to deal with.![]()
I have a 4BD1T & will definitely throw it in my 91 3FE Landcruiser when it dies. Give me the run down on everything I need to make this happen. I need $ amount as well as parts you make to show to the boss and close the deal. Thanks in advance.
SUBSCRIBED!
Sent from my hawn finga using IH8MUD
4L80E $2000
Splitcase $200
FJ62 and FJ80 don't need the Compushift.
93-94 have a seperate transmission controller that may be useable with some input signal modification.
The flywheel pictured is for the automatic Landcruiser application. The flywheel's primary purpose is to hold the ring gear for starting, pilot the torque converter and is engineered to duplicate the inertia in the OE flywheels- Very important in 4 cylinder applications. The holes in the flywheel are to install the converter bolts.
The flywheels are fully CNC machined from 1045 forged steel.
The flexplates are coined from .100" 4130 chromoly steel.
Oh, so its for the auto's, a bit of rotating mass to smooth out the engine on those motors then.
On my cummins there is just a flexplate and not any extra rotating mass with the auto's. Well, before I swapped to the NZV4500 anyway.
For your H55 kits, do you provide a new flywheel? Im guessing the 4BT cummins is still an 8 bolt crank, is the isuzu 8 bolt as well or how what is used for the flywheel for the H55f trans conversions?
Thanks!
The FJ80 Isuzu kit is $1250
Have your converter overhauled with the stall speed changed to 1600-1700 RPM $250
Our Isuzu oil filter relocation block kit $40
A remote oil filter kit of your choice such as one for a PH8A filter around $60
If you were interested in purchasing premade mounts these would be around $200
Buy a Toyota wiring manual for your specific year around $40
Electric fan kit with thermostat (I like the slimline Derale) $210
3" exhaust with a chambered muffler works well and should be around $350 turbo to bumper for an 80 series at a decent muffler shop.
Budget $1000 for hoses, fasteners, filters, oil, tubes, clamps, gaskets, seals, spray paint.
If you want to splurge have the exhaust manifold and turbine housing ceramic coated black. This will run around $200 for both and probably won't make any performance difference, but keeps those two parts looking GREAT pretty much indefinitely.
I see about $3600 in parts there to completely finish your install. $1490 for parts we sell.
Thanks!
So how is the stock gearing go work with the Isuzu?
$1490 with the motor mounts? If so, that's a great deal. My motor even has an intercooler. Had the motor over a year and this is whats been holding it off. I need where and how information. Thanks.
Has anyone researched what inputs the A442F takes from the 1FZFE in the 93-94 model years? It's a standalone tranny computer with a throttle cable to the valve body, so I'm curious if it needs a TPS signal or anything else for shift points. It seems to me this could be made to work without the compushift?
