- Joined
- Nov 22, 2010
- Threads
- 44
- Messages
- 2,151
- Location
- Wilmington, NC
- Website
- www.kindredspiritscsg.com
Glad to hear things are going well now.
Enjoy that truck.
Enjoy that truck.
Enjoy that truck.
Where is the video????
How is the return set up for the hydroboost and power steering, if you have the "tee" in the wrong orientation it could be effecting the fuild flow causing turbulance and aerating the fluid.
It should be straight thru for the return off of the hydroboost and the line from the box coming in perpindicular to it.
If the tee is correct you might want to look into brazing another return into the pump to reduce the fluid velocity or just increase the size of the return into the pump.
I can't wait to get my truck done, and with all of the others cummins swaps finishing up ahead of me its amping me up for what I can expect.
I don't have hydroboost. I have a vacuum pump for the brakes and a steering pimp for the steering (Wonder where I got that from?). I have a line form the steering pump to the steering box and a line from the steering box to the cooler line that runs across the front of the rig and back to the reservoir.
Both of the lines connecting to the steering box have hard flaired, fitted ends. Those two can't fit into the others threads, can they? And, If I put them in the wrong places, will that allow the steering fluid to be pumped through the steering box faster?
Mine is just like yours. I did away with the cruiser cooler line and just put an after market transmission cooler in the front and ran new lines. My cummins had the power steering pump on it and since I had the whole donor truck I was able to pull the lines out with the motor. It actually had return written on the line.
See if this photo is what you have. The really curved line(closest to block) is the input to the steering from the pump on mine.
I love it![]()
Did you forget to put oil in her? LOL
Sounds good and healthy and the reverse snorkel is growing on me too!
Enjoy.
Doug
Did you stay with your mechanical fan or did you do electrics?
