Ask my kids about "Press-release, Press-release"- two people make it go a lot easier and I shut the bleeder off before the clutch pedal is released so air doesn't get sucked back in.
This is key, closing the bleeder before releasing the pedal.
There is a short and and a long-neck throwout bearing, the slave should be fully retracted and barely touching. I don't know but the OEM one has a spring pulling the arm back so it is off of the clutch keeping the TO bearing from spinning all the time and the AA kit I bought didn't have any type of spring at all. I think it is interesting the 2f TO bearing is about twice the size of the chevy stuff.. The clutch slave can be tricky to bleed so make sure there is no air getting in or fluid leaking and your flex hose is good and not expanding either.. Ask my kids about "Press-release, Press-release"- two people make it go a lot easier and I shut the bleeder off before the clutch pedal is released so air doesn't get sucked back in.
what's it sound like now?
I'm starting to think my clutch isn't going to cut it. I have a centerforce dual friction clutch, but no matter how I adjust it, it slips when I hit the power hard in fourth gear. I thought it had 2500 lbs of pressure. Is that not enough? What are some of you guys using?
This rig gets some serious diesel mileage! I haven't figured out what it is yet, but I can go a long way on a littel fuel. I keep thinking my fuel guage is broken!
Those centerforce clutches rely on the weights and centrifugal force to get the peak clamp load advertized. Otherwise, the finger springs aren't that stiff, to allow for an easy pedal. You might not be able to spin it fast enough with that low speed torque monster. Seems to me that design of clutch is better suited to higher revving gas motors. Just a WAG, though...
That's good news. I know all about wrenching at night and not seeing everything right just to have to go back in later and fix things.
Yep, I know about what can happen when you're wrenching outside at night. Did you know it's possible to pit a Chevy disk pad in backwards with the metal backing against the rotor?
That really makes some interesting noises when you're driving to work the next day. People at work will make fun of you too.
Wrenching in the dark sucks! I thought I had enough light with my headlamp, but no.
This is what I call the "What did I do wrong?" stage of the build. I just keep opening the hood and thinking "What the hell is that?".
That's a hell of a quote right there.The only thing that is more unsettling than catching your mechanic doing a crappy job is remembering that you are the mechanic..
