Eskimo
In trying to get a flat, flush skidplate on the FJ, and because of where the tranny and t-case supports are, we're running into an issue with the front output/driveshaft. The crossmember will be approx 4" in FRONT of the output, so clearance needs to be made for the driveshaft. (D/S will be a 2-piece unit, so it will exit straight out the front, angled to the right a little bit)
This picture is a view looking from front to rear..
Black is the frame rails.
RED is 2x4x.120 box tubing (configured as 2" deep, 4" high) used for the crossmember.
BLUE is a flange so the crossmember can be removed.
GREEN on the bottom represents 3/8" x 2" plate that will be welded inside the 2x4, and on the top represents 2 pieces of 1x1x.120 box (one right next to the other, basically making is 1x2x.120)that will be bent to form an arch over the top of the output.
Think this will work? This piece will be the only member supporting the tranny/t-case, and their associated loads. The t-case and tranny are mounted on rubber mounts, but the x-member will be attached solidly to the frame.
My thoughts are that the 3/8" should damn near be enough to support it anyway... but the hoop over the top will add rigidity. The actual unsupported length of 3/8" should be 4-5" long. Since the 3/8" plate will be slid inside the box tubing, we *could* add another 1/8" strip to the bottom of the 3/8" without losing any clearance..
I want something functional, that we can build (i.e. no 4340 or Titanium), that's pleasing to look at at the same time.
