Excellent gents!
I am not tearing into the birfs since I have no issues or clicking on this well cared for LC.
The PO had a brake shop do front rotors and pads at 15k ago so still good but not OEM. I am thinking about doing the OEM rotors with 100 series pads. Is this to OCD?
I just did it and to buy some tools I didn't have, fluids, replace all bearings, all four custom machined rotors, C-Dan kit I went just North of $1600.
Not to mention that the whole ordeal took 10 days. LONG STORY!
If you do not enjoy wrenching on your rig , have bad luck with wrenching on your rig, or don't have many of the needed tools. I would recommend paying someone to do it for you. With the economy the way it is I am sure you can find a fellow Cruiser Head in need of some $$ or a Toyota Mechanic out of work. Just a suggestion because this is a HUGE job and you do get some ignorant confidence from this site.....
Now although mine was a bit of an ordeal, somewhat deflating during the process, about $500 more than I expected now that it is done I did learn quite a bit but I still H8 wrenching on cars!
My 2 cents.
Yeah, I borrowed a grease gun and a flat sided brass drift and had some help taking it apart but it was on me getting it back together. And the receipts add up quick if you really keep track of them. 6 jugs of purple power to clean very dirty knuckle parts, four rotors and pads all around is a nice chunk of change. Inner seals and install tool from Marlin, $90 in fluids, torque wrench, 6 tin turkey trays, etc, & etc. I have a few returns to make but that will probably be about $25 worth....
Isn't there a dvd on this job? Where can it be found if so?
Yeah stripping the knuckle housing by cranking the caliper bolts into it will kinda set you back a few days.
Yes their is a DVD and although I took notes from watching the DVD 3 times it still leaves a few things out. And did anyone else notice that one of the gaskets fell down while they were tightening it all down?
I would loan you the DVD but I borrowed it myself from a local Cruiser guy.
