Cooling system capacity FZJ80 (1994)
Sydney
Hi all, finding it hard to get a definitive answer on what the cooling capacity is for a 1994 FZJ80 1FZ-FE.
I've seen several different figures quoted for this in various sources. If anyone know the correct figure, I'd be very grateful!
Many thanks,
Pete
14.7 litters/3.9 gallons. If you drain from the radiator, block drain on the drivers side of engine and open up the heater controls to hot. I use two full gallons of Toyota red non diluted and two gallons distilled done and done. Goof idea to flush out also till it’s running clear. Do you have FSM for your truck? It’s free to download I the resources section and will give you the exact fluid capacity.
this one in the resources section says 14.2L as well...
It's a hair over 14 litres. Ignore the manual with the 22RE etc listed, you won't find these in an 80.
