Coolant Temp - What's Normal
Minneapolis MN
I've had a few close calls with my 80 and overheating. It's terrifying. I know there's a temp gauge mod I can do. And I probably will. Until then, I'm going to install an aftermarket gauge.
Two questions about that:
1: Is there a gauge or install method that is preferred?
2: What would be considered a normal temp range, and what would be the limit of a scary "Shut it Down NOW" temperature? The temp where anything higher causes cracked heads, blown gaskets, etc?
That is the Landtank/RavenTai temp gauge mod. This worked fine when there was no alternative like UltraGauge and ScanGauge2. I will tell you from a LOT of experience that the mod *could* drive you completely mad with paranoia. Unless you knew exactly what those temps mean and how they affect the driveability and engine management, its useless.
What kind? I'd recommend ScanGauge2/UltraGauge to start because that will tell you what the ECU sees. An aftermarket gauge like AutoMeter works great and gives you *possibly* real world but its likely not exactly what the ECU sees.
ScanGauge2 or UltraGauge
180º to about 215ºish is normal operating temps. That is where the stock analog gauge from Mr. T that says you are good to go. At 227º the A/C shuts off. This is your wake up call that you are in serious enough concern that the truck is starting to take action to keep from going too far hotter.
Don't do that. Keep it running and keep the RPMs higher than idle. Get out and dump water on the radiator and it's fins. That is the quickest way to cool things down. Turning off the motor when you are 230º+ and your engine suffers heat soak. The temps will climb still before it cools. Serious damage can and will happen. This of course assumes you have a properly working water pump, thermostat and radiator.
And just so you know I have gone thru some crazy methods of trying to cool down my truck because it was constantly overheating. If you can stomach it:
• During the rebuild the SC thermostat, all hoses, all belts, water pump were replaced with all OEM:
https://forum.ih8mud.com/threads/engine-rebuilding-options-for-s-c.553208/page-8#post-7367876
• or so I thought. Tstat was Beck Arnley, replaced with OEM:
https://forum.ih8mud.com/threads/im-...erheating-despite-best-efforts.813023/page-43
• In April, before my big Yellowstone trip, I replaced my s***ty radiator with a Ron Davis all aluminum radiator:
https://forum.ih8mud.com/threads/new...ing-into-stupidity.802799/page-4#post-9227967
• Entire cooling system was flushed and then flushed again with distilled then filled with 50/50 Toyota RED and distilled:
https://forum.ih8mud.com/threads/new...ing-into-stupidity.802799/page-3#post-9196744
• Exhaust manifolds and shields were ceramic coated:
https://forum.ih8mud.com/threads/engine-rebuilding-options-for-s-c.553208/page-6#post-7347657
• Heater control valve replaced with OEM:
https://forum.ih8mud.com/threads/engine-rebuilding-options-for-s-c.553208/page-22#post-7700890
• AISIN blue hub fan clutch new from Amazon and filled with 30k CST and adjusted to 105º, fan roars on start up and roars when driving:
https://forum.ih8mud.com/threads/blue-fan-clutch-mod.102633/page-34#post-9227333
• Radiator misting system added to reduce spiking temps:
https://forum.ih8mud.com/threads/new...ing-into-stupidity.802799/page-4#post-9226672
• Added flush hose to also allow for burping the cooling system:
https://forum.ih8mud.com/threads/new...ing-into-stupidity.802799/page-5#post-9233838
• Louvers added to the hood:
https://forum.ih8mud.com/threads/my-newly-vented-hood-20-photos.386741/page-6#post-6768429
• Replaced fan with the original 1FZ fan and Landtank's Orange Hub fan clutch fan
• Replaced new OEM radiator cap for kicks
• Dumped in a bottle of Water Wetter per suggestions
• Replaced all of the missing radiator foam on both sides of the radiator:
https://forum.ih8mud.com/threads/new...ing-into-stupidity.802799/page-5#post-9228020
• Added JDM fan years ago:
https://forum.ih8mud.com/threads/jdm-aux-fan-install-it-doesnt-get-easier.160331/
• Fresh oil change less than 5000k ago with Mobil 1 Syn:
https://forum.ih8mud.com/threads/how-to-oil-change-for-the-non-purists-to-complain-about.807853/
• Timing is set to factory 3º
• Running cooler MR2 plugs
• Catalytic converters and Y-pipe replaced with CA carb compliant FlowMasters (Feb 2014):
https://forum.ih8mud.com/threads/im-...erheating-despite-best-efforts.813023/page-70
• Installed Safari Snorkel which changed my IAFº temps MAJORLY:
https://forum.ih8mud.com/threads/im-...pite-best-efforts.813023/page-69#post-9578218
• Added Photoman's billet water pump pulley which is 15% smaller which makes the water pump spin faster at lower RPMS:
https://forum.ih8mud.com/threads/im-...pite-best-efforts.813023/page-63#post-9362600
Most report, myself included, somewhere between 190 and 200 but there are variables like, what is outside air temp, and how are you using it at that particular time.
You have had "a few close calls" with over heating? A 50/50 mix does not boil until 265. How hot is too hot for our aluminum head engine? Honestly I don't know but I suppose it depends on how frequently it gets very hot and how long it stays hot. I do know that there is a temp sensor called the "ECT cut switch" that cuts off the AC when water temp reaches 226. This info may give you some reference as to toyota's idea of "it's getting hot now". It sounds like you may need to address some cooling system issues because the 80 has a pretty robust cooling system and should never have trouble under "normal" conditions unless something is wrong.
1. You've got a '96 so go with a scangauge. All the earlier guys usually do a koso gauge.
2. My preference is 185-205F. Toyota shuts off the A/C at 226F. I wouldn't be comfortable running in the 210-220F range long term.
I prefer the ultra-gauge bigger display, shows more info on the main screen and the larger font is easier to read at a glance.
Hey - I like that one - thanks! Looks like there are three models. Which one do you have?
Mine is old, one of the first ones. The basic one is best for this application, most of the stuff on the upgraded units isn't available on our early ECU. The windshield mount works well and is priced right.
That was my understanding of the UG as well. The basic model covered the 80's ability, the other models had features not used for our trucks.
(In my case having a '94 I went with a Koso)
That is the Landtank/RavenTai temp gauge mod. This worked fine when there was no alternative like UltraGauge and ScanGauge2. I will tell you from a LOT of experience that the mod *could* drive you completely mad with paranoia. Unless you knew exactly what those temps mean and how they affect the driveability and engine management, its useless.SNIP
What kind? I'd recommend ScanGauge2/UltraGauge to start because that will tell you what the ECU sees. SNIP
180º to about 215ºish is normal operating temps. That is where the stock analog gauge from Mr. T that says you are good to go. At 227º the A/C shuts off. This is your wake up call...
I'll also sing the praises of the SG/UG. But it's the one that makes me panic. I had the Raventai gauge mod for several years before I bought a Scangauge. I'd even memorized the cheat sheet I have taped to the glovebox door in case I needed, so I knew roughly what the stock gauge face was pointing at. Even went through a radiator R&R after concluding the original was finally clogged. But it wasn't until that digital readout was staring me in the face that I really got nervous. 219? Really? Fortunately just brief spikes along the way as things got sorted out and I modded the fan clutch, too.
But those numbers in my face...that's what scared me...:eek:...until I reconciled the two gauges to my experience. I feel better now.o_O
i typically run between 195 and 210. 211 being the hottest but that was crawling with the cdl and in sand on a 108 degree day. 33" km2s and red green mix that will be replaced very soon when i do the phh-bs
Not sure about the SG, but the UG you can set a audible alarm which is nice.
Now that Tools reworked my LandTanked clutch, I've yet to see more than 204* here in AZ and that is pushing her pretty hard and loaded out of Black Canyon on the 17. Most of the time 184.6 is what I see even this time of year. If I idle for a long time with the AC on, I'm between 190-194 with the AC blowing 40*, IAT 150ish and OAT 110.
