Coolant Temp - What's Normal
The Orange Hub has seriously changed the entire cooling characteristics of my SC'd truck!
good to know, gotta find some time to put it on, too busy working on other people's truck, lol, which I guess is good....
True, the actual load from the AC is around 5 degrees C as observed with my cooling system mods but, the engine is still too hot at idle. Fan/shroud/air in system/lazy thermostat/baffles around radiator/excessive clearance water pump impeller to pump body/hoses collapsing/poor sealing at the fire ring on the head gasket/corrosion in the block/timing.....it goes on.
I would start base lining, new stat but check it BEFORE putting it in is a good place to start.
regards
Dave
Ok so it sounds like the torque app with wireless Bluetooth dongle is dead on in terms of temps.
On the highway I was running at 194-198 with no AC on. Turned on the AC and in a couple minutes I was right at 203 [there is the 5 degree load].
75 mph outside temp about 80.
Long country road at 60 mph with AC on Temps 199.4.
In town at stop lights it got as high as 208.
The truck at some point had a flush and filled with green. Would new T stat and red coolant help?
But again only 80 ish out today. Not mid 90s out when it would hit 226.
The red coolant is not magical. The green works fine and can be had, on sale, at a fraction of the cost of toyota red.
Has the radiator ever been replaced? Your issue doesn't sound too severe. There is a reason a 50/50 coolant/H2O mix does not boil until 265F. I know the 1FZ has an aluminum head and is a bit more touchy than an iron head would be but 210-215F in the summer with A/C on in a low speed situation does not seem like a problem to me. And yes I remember that you stated you reached 226 and your A/C shut down. The system worked.
Consider yourself lucky. I'm still out of work :(
me too! this pays a little for costco trips, lol, still looking for a job in healthcare, ultrasound technologist, licensed but can't find a place to take a new graduate and train them!
I just started working again a couple of months ago. Finally getting my feet back under me. And just found out today that I am getting a "promotion". I took a job that I was overqualified for as a "stop gap" until I found something better. Things are finally starting to work out.
I think I need to do that. I'll go sweep floors at Target.
Exactly what I needed to know. I'm ordering mine tonight.
PS - I've been using an OBD2 unit with wifi connected to my phone. Today's coolant temp has been below 195* with ambient temps at about 85-90*. And with a dripping hose from "somewhere" on the drivers side. I'll be doing the PHH bypass and the rear heater bypass this weekend. Hopefully that will solve the slow drip.
Maybe a dumb question, but if you are using OBD2 unit with wifi and your phone app, why do you need an additional SG or UG unit? Don't they take the same readings more or less?
You won't get a 'tug' by the police for looking at your dashboard.
regards
Dave
I speak about SG, having one: It can only show 4 pieces of data at a time. Hence, if we wanted to see, say, IAT, WT, TPS, and RPM, and we also wanted to see speed and battery voltage, we'd need to use another SG. The app + bluetooth adapter are cheaper. That is why one might use both. Just my guess.
