Which stuff?
You know there's a boss on the water neck you could have drilled and tapped. I'd actually would have wanted to see what sort of drop in temp you get after the radiator. You can run two senders on one gage with switch. I use to do that with a sender in my auto transmission pan and one in the oil pan on my old tow pig 454 suburban.View attachment 904800 View attachment 904801 Next up
I wanted to know the temp of the coolant going into the radiator. I may automate turning on the misters using this temp.
bump, can you post some pics of where you installed that ac foam on your radiator? I am installing an al rad right now and am wondering where this should be done? Only plans as of now were to install a small foam strip between the shroud and radiator. Thanks!
