Coolant Temp - What's Normal
Mine is old, one of the first ones. The basic one is best for this application, most of the stuff on the upgraded units isn't available on our early ECU. The windshield mount works well and is priced right.
Exactly what I needed to know. I'm ordering mine tonight.
PS - I've been using an OBD2 unit with wifi connected to my phone. Today's coolant temp has been below 195* with ambient temps at about 85-90*. And with a dripping hose from "somewhere" on the drivers side. I'll be doing the PHH bypass and the rear heater bypass this weekend. Hopefully that will solve the slow drip.
Driver's side, back towards the firewall = PHH (generally)
It's wasn't that bad. I retained the factory config when I did mine, but upgraded the hose.
How is it connected? Via the OBD2 port? Does that prevent you from using the fuse panel cover?
That's how mine is. Big L-head plug protrudes about 3/8 proud of where the panel cover surface would be if in place and cable points toward the steering column so you can route it where convenient. Panel cover no long fits. I've debated trimming the panel cover so it fits around the plug. Wonder if anyone has done that?
You really don't see it in your field of vision except when preparing to get in the truck.
Yep, I don't run the cover. Could relocate the plug, but here, the plug must be in the correct location or it will fail emissions for tampering.:rolleyes: Could relocate, put it back before emissions, then relocate, repeat, not worth it to me.:hillbilly:
Yeah - I noticed the panel would be out of view when driving, so probably not the end of the world, considering the benefit of the gauge. Thanks for the responses!
PS - I ordered mine. Should be on the way soon!
Now you get to look forward to programing it, kinda kludgy/akward! It has the option for multiple screens (IIRC 6?) I turned that off and programed the stuff I wanted on the main screen. They have tons of alarms, the most annoying is the unit temp, here, in the summer, it goes off almost every time the rig is started. I turned all of them off, then programed the coolant temp to wake me at ~220F.:hillbilly:
You can use one of these and put all the connections behind the dash and still have the stock look in the fuse box.
im not ting to hijack this thread but i had mine out saturday night when the temprature was in the upper 90s and all was well when i was on the hard pack but when i got to the sand the temprature rose to 120. i stopped and let it run abit and it went down to 195. when i continued it rose again. when i got out of the sand it went back down to 198 and held. im noticing it does it at lower speeds mostly and im guessing its probably the fan clutch. is this a fair guess? i imagine that the coolent (which i havnt changed yet) has something to do with it. red and green mix from the PO. i havnt done the phh yet. no time. no lift and 33" km2...
i have a blue hub on order and will be doing t mod but i cant find the original thread for it... lol
No better question than an on-topic one related to off-road performance. Sand is going to be a considerably greater load on the drivetrain than hard surfaces. Lots of drag on the tires, as they run settling into the stuff. Temps will rise.
I gotta ask, were you in Low or High range? Because going to Low helps keep engine revs up, thus fan revs up when you have a heavy load on, as when going through sand. You don't want to overspeed in Low, but it does help give the truck more power to deal with the extra drag or the sand also.
Do you manually shift down, and do you air down?
didnt air down but tried both high and low. same result. maybe im just compairing it to a lighter vehicle... coughjeepcough...
i dont get any of that in the other vehicle with the same psi and tires...
im still getting used my 80 but ill fing what she likes and doesnt like. the fan seems to rotate just over a full revolution when i shut it down and with any fanclutch thats too much.
Adjust your fan clutch opening to 95F and throw some new fluid in there. Probably fix your problem.
i already have a blue hub on order. to tell the truth, i didnt even think of doing it to the original... lol
oh well. does anyone have the link to the original thread for the mod or how to adjust? i used the search but there was conversation after conversation but not really explaining how to adjust...
SNIP
heh, heh, well it's not one of those lightweight jeeps:confused:
Real men do air down, BTW.:rolleyes:
inkpot's airing down question is a very wise one, because most of the time, it solves the traction problem by giving you what is effectively a much larger footprint. Depending on your tires and the qualities of the sand involved, you can go from needing no airing down (I'm thinking those big fat sand tires specialized to this use, but in the old days simply old aircraft tires) to something like my KM2s, which really need that extra help in sand, because of the narrow width and lugged tread.
I'll admit I air down less than I should, but when you gotta, you gotta. A man has to know his limits and all that...
My point about shifting was about manually shifting the transmission: 1-2-3-D. Leaving it in Drive will let it shilft into the highest gear possible, which will lower rpm and fan speed, reducing cooling ability.
I haven't wheeled a lot in sand, but correct. Airing down is key in that environment. Wheeling the 80 in teh dunes is not nearly as fun as I thought. Use low and airdown. (no idea on the heat issue, but mine ran a lot warmer than normal having it tack'd out playing in the sand)
And just so you know I have gone thru some crazy methods of trying to cool down my truck because it was constantly overheating. If you can stomach it:
• During the rebuild the SC thermostat, all hoses, all belts, water pump were replaced with all OEM:
https://forum.ih8mud.com/threads/engine-rebuilding-options-for-s-c.553208/page-8#post-7367876
• or so I thought. Tstat was Beck Arnley, replaced with OEM:
https://forum.ih8mud.com/threads/im-...erheating-despite-best-efforts.813023/page-43
• In April, before my big Yellowstone trip, I replaced my s***ty radiator with a Ron Davis all aluminum radiator:
https://forum.ih8mud.com/threads/new...ing-into-stupidity.802799/page-4#post-9227967
• Entire cooling system was flushed and then flushed again with distilled then filled with 50/50 Toyota RED and distilled:
https://forum.ih8mud.com/threads/new...ing-into-stupidity.802799/page-3#post-9196744
• Exhaust manifolds and shields were ceramic coated:
https://forum.ih8mud.com/threads/engine-rebuilding-options-for-s-c.553208/page-6#post-7347657
• Heater control valve replaced with OEM:
https://forum.ih8mud.com/threads/engine-rebuilding-options-for-s-c.553208/page-22#post-7700890
• AISIN blue hub fan clutch new from Amazon and filled with 30k CST and adjusted to 105º, fan roars on start up and roars when driving:
https://forum.ih8mud.com/threads/blue-fan-clutch-mod.102633/page-34#post-9227333
• Radiator misting system added to reduce spiking temps:
https://forum.ih8mud.com/threads/new...ing-into-stupidity.802799/page-4#post-9226672
• Added flush hose to also allow for burping the cooling system:
https://forum.ih8mud.com/threads/new...ing-into-stupidity.802799/page-5#post-9233838
• Louvers added to the hood:
https://forum.ih8mud.com/threads/my-newly-vented-hood-20-photos.386741/page-6#post-6768429
• Replaced fan with the original 1FZ fan and Landtank's Orange Hub fan clutch fan
• Replaced new OEM radiator cap for kicks
• Dumped in a bottle of Water Wetter per suggestions
• Replaced all of the missing radiator foam on both sides of the radiator:
https://forum.ih8mud.com/threads/new...ing-into-stupidity.802799/page-5#post-9228020
• Added JDM fan years ago:
https://forum.ih8mud.com/threads/jdm-aux-fan-install-it-doesnt-get-easier.160331/
• Fresh oil change less than 5000k ago with Mobil 1 Syn:
https://forum.ih8mud.com/threads/how-to-oil-change-for-the-non-purists-to-complain-about.807853/
• Timing is set to factory 3º
• Running cooler MR2 plugs
• Catalytic converters and Y-pipe replaced with CA carb compliant FlowMasters (Feb 2014):
https://forum.ih8mud.com/threads/im-...erheating-despite-best-efforts.813023/page-70
• Installed Safari Snorkel which changed my IAFº temps MAJORLY:
https://forum.ih8mud.com/threads/im-...pite-best-efforts.813023/page-69#post-9578218
• Added Photoman's billet water pump pulley which is 15% smaller which makes the water pump spin faster at lower RPMS:
https://forum.ih8mud.com/threads/im-...pite-best-efforts.813023/page-63#post-9362600
Wait, Joey had overheating issues? I hadn't heard... :flipoff2:
