That looks an awful lot like sand and clay. Powdered clay, when wetted, will make a sludge with a consistency varying between sour cream and cream cheese, depending on water content. Both sand and clay are used in sand casting. The clay provides a cohesive bond to hold the sand particles together. The sand grains are typically round and fine.
I found this description of post casting cleanup (http://www.metal-technologies.com/sand.asp) -
"Melting & Pouring
Melting is the preparation of the metal for casting, and its conversion from a solid to a liquid state in a furnace. It is then transferred in a ladle to the molding area of the foundry where it is poured into the molds. After the metal has solidified, the molds are vibrated to remove the sand from the casting, a process called shakeout.
Cleaning
Cleaning generally refers to the removal of all materials that are not part of the finished casting. Rough cleaning is the removal of the gating systems from the casting. Initial finishing removes any residual mold or core sand that remains on the piece after it is free of the mold. Trimming removes any superfluous metal. In the last stages of finishing, the surface of the casting is cleaned for improved appearance. In addition, at this point, the casting is inspected for defects and adherence to quality standards. This inspection may include nondestructive testing to determine whether the part will adequately perform for its intended use."
In something with as many internal passages as an engine block I would not be at all surprised if there were a small amount of residual material that was left. In fact, it could be partially bonded to the cast metal and is only released over time as the metal is worn through corrosion or fluid flow.
This would not explain why we don't see this in other engines, though. Are the LC blocks made by a single source? Are any other blocks made at the same factory? It may just be differences in the manufacturing process and/or the sand used in the molds.
"Melting & Pouring
Cleaning
