Hi ,
I have a 2.4 diesel hilux (1995), can I modify it to a 5L ?
Thanks
Jacob
Just doing a 2-5 swap at the moment, do you not rate the 5L?"Can it be done?" Absolutely.
"Should it be done?" Different story.
Disregard - I was thinking of a different engine.Just doing a 2-5 swap at the moment, do you not rate the 5L?
Mostly going to the 5 because it has bigger Piston pins, I snapped two pins on the last 2l I turbocharged
You must be talking about the early 2L(T). The 1990+ 2LT-II and 2LTE have the same sized piston pin diameter and big end connecting rod bore as the 5L engine.
it was a 1997 2L non turbo turned the fuel up 2 turns 30psi and when I took it down the 1/4 I gave it a 50hp shot of NOS
I am building a compound setup at the moment
GT2876RSounds like fun! Not sure how big the rods are on the non turbo 2L; maybe smaller; not sure.
What turbo were you getting 30psi out of? Which injection pump? 12mm?
It shouldnt be too hard.
[/QUOT
Thanks, 5L engines are almost impossible to get hold of in Israel, I did one rebuild from 2lt to 3L.
Not quit sure about the 5L engine, what is the real difference ( in performance) ?
Im not sure but this may give you some ideaNot quit sure about the 5L engine, what is the real difference ( in performance) ?
I currently just bought an 1984 Toyota pickup diesel 2L motor and I need to replace the cylinder head on it. I have looked high and low for a replacement OEM Toyota head and cannot source one here in Oregon. Anybody have any leads to one it can just be a bare head ready to install if you have one let me know or where I can find one. Thanks Johnny
