Note: This feature currently requires accessing the site using the built-in Safari browser.
I'm getting ready to install Slee castor correction bushings and would appreciate any tips on removing the control arms. Thanks in advance for your help.
good tip on turning the wheel. I just replaced my bent right side arm last night and by turning the wheel all the way to the right I was able to get the last bolt in.We were having a hard time lining the frame bolt back up, found it was easy to do having some turn the steering and someone else ready to push the bolt in. The bushing eye lined up in one magic spot while turning the wheel.
Before you bolt everything back up, check the tie rod clearance against the control arm. It will save you pulling everything back apart to grind the arms for clearing the tie rod.
Careful with the nuts Kliers mentioned, friend that installed plates recently found the nut missing. We figured he must have flattened the little flaps that keep the nut from backing off.
Gday,
If you leave the front wheels on the ground, you can roll the front diff housing back with the tire. Then I use a pry bar under the spring perch to rotate into position. Ive always done it this way, but some ppl are worried something may fall on them - I dont know what.
Matt
how did you guys remove the rear bolt on the passanger side, looks like the exhaust pipe is in the way.
