Looking for a little advice.
Current list of maintenance that needs to be done has me considering pulling the engine and doing a full rebuild. Goal would be to have an engine that is ready for the addition of a supercharger after the rebuild and wouldn't need anything other than routine maintenance for several years as time is going to be tough to come by (work and growing family).
Current maintenance needed:
Rear main and/or upper pan arch seal
P0401 which will require removal of upper intake
Y-pipe needs to be removed and welded
Headgasket has not been done currently at ~170k
Truck is a hobby and working on it is as big a part of the hobby as driving it for me.
Considering pulling the engine to address all of this. While it is out I would pull it all down, deck the block and have the head gone over. Rebuild with Cometic mls and arp studs and replace all gaskets.
I have only rebuilt one other engine and I had to have that one bored out and larger pistons fitted. I don't expect that will be necessary with this engine. Just a hone to refresh the surface.
So the questions:
-am i correct to assume that as long as I don't find any significant scoring that the re-ring will be straight forward and will allow the reuse of the pistons with just a fresh set of rings.
-Is it a requirement to have the blocked decked to switch to the mls gasket?
Sorry for the long post
So the questions:
