SOLD Concord CA: 1989 FJ62 (4 Viewers)
Year
1989
  1. 60 Series
Concord, California United States
Mileage
303400
Color
Gray
Well the time has come to part with my beloved 62. I purchased it pre-pandemic and did extensive work including repaint, completely new interior including two-layer dynomat throughout. I have had everything except the motor rebuilt, its running so well I haven't seen the point. Work is detailed below, the vast majority of mechanical work has been done with Georg at Valley Hybrids in Stockton CA. For serious buyers I'd be happy setup a call with them, test drive, etc.
Message me with any questions.
$32,000
2023 Rebuilt A440F including Torque Converter
2023 Transfer case rebuilt - Modified with 19 spline shaft to support 4 and 5 speed transmissions
2023 New U Joints Front/Rear
2023 Transmission Cooler installed
2023 New Rear Main Seal
2023 New Oil Pan Gasket
2023 New Starter (OEM Remanufactured)
2023 New Fuel Hoses on intake manifold
2023 New heater hoses
2023 New PCV Valve
2023 New rear pinion seals and new rear diff oil
2021 New Catalytic Converters
2021 New Power steering box
2021 New Power steering hoses
2021 New ARB Headlight Lighting Harness
2020 5 BFG A/Ts 33x10.5 (full size spare)
2020 New Battery wiring and clamp
2020 New Window tracks
2020 New Exhaust and muffler
2020 New Fuel filter
2020 Valve adjustment
2020 New valve cover gasket
2020 New Side Cover Gasket
2020 New Water pump
2020 New cam chain cover gasket
2020 New Heater control valve
2020 New Shifter bushings
2020 New U Joint Front Shaft
2020 New suspension bushings
2020 New Old Man Shocks front (60009) and rear (60065)
2020 New Old Man Emu Steering Stabilizer OME
2020 New rear sway bar bushing
2020 New tie rod ends
2020 Coolant flush
2020 Knuckle Rebuild
2020 New rear brake shoes
2020 New rear wheel cylinders
2020 Machined rear brake drums
2020 New Brake fluid
2020 Replaced gear oil
2020 New Inner Axle seals
2019 New Interior Carpet
2019 New OEM Dash Cap
2019 2 layer dynamat throughout interior
2019 Noico Black 80 Mil Sound Deadening, Butyl Automotive Deadener Restoration mat and Noise dampening Insulation
2019 Noico Red 150 mil (4mm) Noico Liner Car Heat and Sound Insulation,Heat and Cool Liner,
2019 All Interior/dash lights replaced with LEDs
2019 Infinity Basslink MIni Sub under passenger seat
2019 2x Kenwood KFC-1366S
2019 2x Kenwood KFC-1666S
2019 Pioneer DMH-1500NEX - Apple Carplay/Google
2019 Boyo VTL425TJ rear backup camera
2019 Seats Reupholstered
2019 Repainted OEM Correct
Nice write up. GLWS
Gorgeous looking. If this was a 60 I would be all over it.
$32,000
2023 New PCV Valve
2020 New Water pump
2020 Coolant flush
I happened to be delivering mail in the area a few weeks ago and saw this one in person. It looks just as good in real life!
Wish I had the space for it. I'd have to sell my 80.
A bit over my budget and exactly what Im looking for but 4 months too early :bang:
