- Joined
- May 14, 2006
- Threads
- 41
- Messages
- 258
I recently purchased a non-running 85 4Runner, 22re. The owner said it had been running fine, but overheated and now needed a head gasket. The gasket on the timing cover looked somewhat new, so decided just to do the head and get a valve grind and new seats seals etc... So have re-installed the head etc... after doing a compression check, I get numbers of 165-155-150-145 front to back. I realise they are within the manuals recomended "tolerances", but what should I learn from this, are these numbers a problem?
Then out of curiousity, I decided to drop the oilpan. I know now that I should have done that in the first place. In the bottom of the oilpan, I found chunks of timing chain guides. Should I be worried, or can I assume they had done the timing chain before and these were leftover chunks that didn't get removed when the work was done? Any ideas
