Complete A/C system replacement?
Alright, So i'm pretty deep into the system now and everything seems to be going soothly (fingers crossed). I found the major clog, and unstuck it... all over my arm. (see photo)
Ill update with some pics and more info later, but for the moment just a quick question: The Denso compressor I got isnt very clear about the oil situation. It definitely came filled with some (an ounce or two spilled out) but Im not sure whether it needs new oil, or more oil. Or no oil. I didnt purchase any as I was assuming the new compressor would have the oil it needed.
Thanks!
I never use the oil that is shipped in the Compressor. Drain it all out. Get an 8 oz. bottle of Pag 46. Since you are pretty much replacing all of your components and flushing the lines, it is best to just use all new oil of a KNOWN amount. IF you overcharge with oil...you won't realize maximum cooling. Of course... too little means premature failure of the compressor.
I like to put about an ounce of oil in the Evaporator, 1/2 ounce in the drier, couple of ounces in the Condenser and the rest in the compressor (8 ozs total).
After you have reassembled the unit, pulled a vacuum and liquid charged into the high side (BUT BEFORE you connect the belt to the compressor to vapor charge the remaining amount in the low side) I will hand turn the compressor 15-20 revolutions. Then connect your belt, and finish charging the system (vapor) though the low side.
You should have plenty of oil in all the places needed for start up. Remember...it is the refrigerant that carries the oil through the system.
Note: Make darn sure you have ALL the crud out of everything before you button it back it up. Use new O-Rings and (Nylog) on your fittings, you'll never have leaks that way.
That looks like desiccant from the receiver/drier. I would attempt to flush the lines, evaporator, and condenser with R-11 flush and dry nitrogen by removing each component and flushing separately. Replace compressor, receiver, and expansion valve. Pressure test, evacuate, and weigh in fresh refrigerant. Good to go.
anyone have a part number they like from any manufacturer for schrader valves?
preferred removal tool?
thanks!
Alright, end of Day 1, here's where we're at: Blowing kind cold, but not really cold.
I started by pulling the evaporator which was badly clogged with leaves and debris. All in all, not as hard as I thought it was going to be. I replaced it along with the expansion valve. I replaced the dryer as well as the compressor ( the condenser had already been done by a shop). I then worked through all of the lines one by one taking them out, blowing them clean with compressed air and changing all o-rings and adding Nylog. Got everything buttoned back up and pulled a vacuum with the pump. This may be where I messed up... I pulled the vacuum for over an hour. I watched some tutorials which said to leave the hi side closed off during the vacuum, which is what I did. It pulled to around 25-27 (very hard to read on my gauge) on the low side. I then put about 2.75 small cans of R134a in the system. It took halfway into the 3rd can before the compressor ever kicked on, and when the 3rd can was done it was only blowing mildly cold. I stopped there because it was late and i didnt want to overcharge the system.
Here's what I think might have happened:
1. By running the pump with the hi side closed off, I may not have pulled a good enough vacuum. The gauge said it reached around 25ish, but hard to tell exactly. This might explain why it took ages to get the refrigerant into the system.
2. Because I didnt have the adapter to use the freon cans with my gauge set, i used an old cheapo gauge and hose from a DIY freon kit. Because it's pretty inaccurate, I can't actually tell how much freon went into the system and how much I accidentally lost/wasted (there was a little leakage). It could still be warm because its still low on refrigerant.
Those are my two best guesses for whats going on. Tomorrow I'll try to find the adapter to use the gauge set with the small r134 cans so i can get a better reading. Trying to decide if I should evacuate and re-vacuum, or see if the level is low and add more refrigerant. Can a system read fully charged, but perform poorly due to being under vacuumed?
Also, I did not distribute the 8oz of PAG oil between the components as suggested above. Instead, I emptied the new compressor, filled it with an 8oz bottle and rotated the wheel to distribute. Will this cause long term issues? It might be a moot point now since the system has been run for about an hour as is.
Ok, figured out the gauge reading. Ignore last post.
I get the adapter I need to use the freon bottles with the gauges. I evacuated the freon and pumped it Back down for about an hour +. It pumped down quicker and stronger than last time, around -30 this time.
I've tried adding the freon now via the new adapter and gauge setup and... nothing. Despite having a solid vacuum it just won't suck in the freon at all. I'm really at a loss here...
This is strange: This morning I put the gauges on it and both sides read right at 0. Doesnt matter opened or closed or compressor on/off. How can it read like this if theres 2-3 cans of freon in there?
Edit: You posted while I was typing this, so some of it does not now apply. Read it anyway.
Just press on the low side shrader valve (briefly) to see if you get a forceful discharge. If not....you have a serious leak or complete blockage somewhere.
We will assume your gauges are in good working order?
You should have 'some' reading of the static pressure IF there is any refrigerant in the system. It should be roughly equalized (showing about the same pressure for both sides) when the system is off and the gauges are hooked up to the high and low side. There is a specific pressure reading (static pressure) for every corresponding degree in temperature for all refrigerants. In your case (134a) for example, at 80° F you should see about 88 psi of static pressure IF you have enough refrigerant in the system that some portion of it is liquid.
I have to say...I am really disappointed to see that you went to as much trouble to replace the system and then took 'short cuts' right at the end.
Did you flush the Condenser or at least purge it with air? You mentioned doing all the other components and lines. The crud in the picture you provided in post #37 looks like a combination of desiccant particles (usually appears as beach sand), compressor oil and possibly some stop leak. ALL of that needs to be gone before putting the system back together.
Always vacuum the system with both the high side and low side valves open. Use a decent pump to achieve at least 28 in. vacuum. Then let the unit sit for about 30 minutes to see if there is any significant leakage. If not...then (and only then) proceed to charge the system.
There are different ways to charge the system, but I prefer to liquid charge the first can/pound into vacuum from the high side. That way you quickly introduce enough refrigerant that the compressor will immediately engage and circulate oil in the system. The rest of the charge can be installed (vapor) through the low side.
When charging a NEW/Evacuated system....don't rely on the gauges to tell you how much. The system is designed to work best using a specific amount of refrigerant. So 'weigh' it in. Then use the gauges to fine tune it and check for proper function.
There is no telling how much refrigerant you might have in the system at this point. We don't know how deep a vacuum you actually pulled on it. Don't know if you have air in the system. Sounds like you still have a leak unless your gauges are faulty.
Always best NOT to proceed until you have all the tools necessary to do the job (can adapters, etc).
If it were me, I'd evacuate the system (if there is any pressure) Blow out one or more of the lines into a white cloth and look for any dark colored contaminants. If all looks good button it back up. Pull a vacuum and CHECK for the system to hold the vacuum. It it doesn't, you still have a leak you will need to find. IF it does hold, then proceed with charging it.
Don't take short-cuts and don't rush the job. You have too much time and money into it....to risk having to start over. That is why I am such an A/C 'snob' about doing it right (the first time). Not trying berate your efforts or scold in any way. Just trying to save you some trouble.
Flint.
Vacuum looks good. Does the system HOLD the vacuum for at least 30 minutes?
Explain your procedure for adding the refrigerant, starting right after you have pumped the system down. What valves have you opened and closed and in what sequence?
Always vacuum the system the with both the high side and low side valves open. Use a decent pump to achieve at least 28 in. vacuum. Then let the unit sit for about 30 minutes to see if there is any significant leakage. If not...then (and only then) proceed to charge the system.
Flint.
Exactly this ^^^
@flintknapper can you explain how for a newb charging liquid vs vapor? Is it just a matter of what port youre putting it into or ...?
@flintknapper Thanks for taking the time for the detailed reply.
Firstly, I believe the system to not be leaking or blocked. It held pressure overnight (there was a forceful discharge from the low side shrader this morning and after I vacuum in down, it holds -30 for an hour.
When I replaced the parts in the system I blew out/ flushed every line with flush solution and compressed air until nothing but air came out the other side. I believe the system is free of contaminates. I could disconnect and recheck everything, but I was very thorough yesterday as I knew this was my main problem.
Here's where I'm at today:
Currently I have evacuated the system until there was no pressure left. I then reconnected the pump, with both high and low side open, and pumped it down until it reached -30. I waited an hour, came back to find it held pressure, and vacuumed a bit more to remove any additional moisture.
I closed off both valves on the gauges as well as the valve for the yellow line. I removed the yellow line from the pump and I connected the yellow line to the can. I turned the car on (AC on high) and opened the valve to the can, and the valve for the yellow tube on the gauges. I then slowly opened the low side valve on the gauge waiting to see freon being sucked in through the sight glass. This is where Im at now, nothing is happening. From what Ive read/ watched it should start sucking right away if there is a good vacuum on the system, correct?
Im not sure if its my order of operations that wrong, that I need to open it and give it more time, or that something is blocked inside the system.
I did try liquid charging from the high side with the engine off, but again, nothing got sucked in.
I did not blow out the condenser itself because after it was attached to the system, the system was never charged up or run. I can blow it out just in case though.
EDIT: Blew out the condenser. All clear.
Also, Agree with @kruisinkid. I did a google search but couldn't turn up much. My assumption was that you hooked the gauges and freon up normally as if you were going to charge through the low side, but instead inverted the can and opened the high side valve.
yeah my own searching led me to believe to get liquid you turn the can upside down, vapor is valve side up (normal). yeah i would assume open the high valve for the liquid, only putting in 1 can of liquid for initial charges, then the rest as vapor. a bowl of water was involved too to cool the can i would guess. it was a youtube video with a long description.
all that being said, i myself am happy to gut and replace and clean the system, the real labor end. i would never attempt to charge or vac the system myself. im not going to go out and buy all the gear to do this once every couple years. i tried last summer to debug myself and bought the crappy gauge set from harbor freight. for a weekend mechanic like most of us, i believe it to be well worth it to take it to a pro to vac and charge the system.
Just did the whole process all over again. Pull vacuum to 30. Test for an hour. Charge with freon.
This time I got the full 30 oz in but it's only running at 60 degrees. What is the most likely culprit for this? My only guess would be somehow I'm not evacuating all of the air/moisture from the system and it's not able to cool to its fullest potential. Either I'm letting some vacuum escape accidentally, or I'm not vacuuming long enough...
Could too much PAG oil cause this? I emptied the new compressor fully and put in an 8 oz bottle per @flintknappers instructions. But maybe there was some I couldn't get out.
is your heater valve at the top center of the engine bay fully closed?
You can rent it for free from AutoZone.
Yes.
First, lets understand WHEN it is appropriate to 'liquid charge' a system. You NEVER want a liquid charge in the LOW side (it can slug your compressor). The ONLY time I liquid charge...is when there has been a complete evacuation of the system.
Now that we know WHEN we might choose to liquid charge (into vacuum, engine off) a system, let us understand WHY we do it. The reason(s) to liquid charge the system (initial charge).
1. Liquid charging the first can/12 ozs. into the high side (Into Vacuum) gets 12 ozs. (if using disposable cans) into the system quickly. Typically less than a minute.
2. Liquid charging (into the high side into vacuum) lets you get at least 12 ozs. of refrigerant into the system so that it can carry the compressor oil (lubricant) with it right from start up. You will also have enough pressure to activate the low pressure sensor...so the compressor clutch will operate right away when you go to finish filling the system (via the low side as a vapor).
How do we do this?
Starting from a condition where the system has been pumped down (deep vacuum) to between 28-30 inHg. All valves closed (valves were closed with vacuum pump still running) to avoid losing any vacuum.
Conditions: ENGINE OFF, System has held vacuum for at least 30 minutes, High and Low side hoses still connected, Yellow charging hose disconnected from pump.
1. Connect yellow hose to can using appropriate adapter. IF using a side piercing adapter, install/pierce near the top or bottom of can (not in the center). We are going to invert the can so the liquid is nearest the piercing point later when we charge.
2. Slowly unscrew the fitting of the yellow hose at the manifold gauge just until a small amount of refrigerant escapes past the threads, then re-tighten. This will purge any air (atmosphere) from that line and prevent any from entering the system. Some hoses have a shrader valve at that location that you can depress to do the same thing. Just be sure to purge the line. Be careful! Just barely crack the fitting to let a little refrigerant out.
3. Invert the refrigerant can so that the liquid refrigerant is nearest the 'tap' (adapter) and keep it in this position.
4. Slowly open the high side valve (until fully open) while making sure the can stays inverted, do not shake, just let the refrigerant be drawn in. You will physically be able to feel the can getting lighter. It shouldn't take too long (typically less than a couple of minutes). The Deep Vacuum will pull the refrigerant into the system. As this process nears its end...the can will become quite cold and the outside might even frost over.
5. Once you are satisfied the can (approx. 12 ozs) has gone into the system, shut off the high side valve, we won't be using/opening it anymore. Leave the hose hooked up, we still need it for gauge readings later.
6. At this point you are ready to finish filling the system via the LOW SIDE port. There is no more 'vacuum' in the system, we now have a certain amount of pressure (depending upon ambient temp). All future refrigerant will be drawn in as a VAPOR (we don't want liquid, or only very small amounts) going through the compressor. This will be drawn in by the compressor itself and through the LOW SIDE port.
7. So...with High and Low side valves CLOSED, we are ready to connect another can of refrigerant to the yellow hose (with adapter). Connect another can, then just as before....'purge' the yellow line at the manifold connection (just let a little refrigerant escape, then re-tighten it, or use the shrader valve if so equipped).
8. I like to hand turn the compressor 10-15 revolutions (belt(s) off) before installing the belt and running the compressor to insure it turns freely, has no liquid refrigerant in it (that can slug it) and to distribute some of the oil prior to start up. But this extra step is up to you.
9. Now lets start charging the remaining amount of refrigerant (whatever amount your vehicle calls for) as a VAPOR into the low side port. With the refrigerant connected and that line purged, we now need to purge the low side line (blue line). Just slowly crack that fitting (just as you did the yellow line) until a little bit of pressure escapes, then tighten it back up. Now we are ready to go.
10. With your A/C on 'high' and the windows (or doors open), start the engine and your compressor 'should' already be running (clutch engaged). Make sure your refrigerant can has the tap facing UPWARD...so that only gas/vapor will be drawn out. Remember we don't want liquid refrigerant going through the compressor (at least not your first time, pro's and experienced DIYers know how to 'force' feed it, but DON'T do it for now).
11. Slowly....open the low side valve and allow a small amount of refrigerant to be drawn in. DO NOT fully open the valve, DO NOT shake or invert the can at this point. Just open the valve about a quarter turn and watch your low side gauge. IF the pressure goes above 85-100 psi, turn the valve off for a minute or so and let the system 'settle' or open the valve to a lesser degree. This is going to take some time, so don't rush it. Depending upon the ambient temperature and humidity....it can be difficult to get the remaining charge of refrigerant into the system at times.
12. Continue to charge the system based on WEIGHT of refrigerant, not gauge readings (for a full system recharge). We will use the gauges to fine tune the charge later if need be.
Notes: Go slowly, be sure have turned off all valves before connecting cans of refrigerant and that you PURGE the low side line and refrigerant line each time BEFORE opening any valves to charge the system. Even small amounts of air and moisture will affect the performance of your system.
Make sure you have pulled a deep vacuum on the system (28-30 inHg). This will remove air and moisture. If the system has been open to atmosphere for very long, then plan on pumping it down for a couple of hours or more. It takes time to boil off and extract the moisture.
The point of creating a vacuum (besides removing the air) is to remove the moisture in the system. It has to boil off. The less pressure on the water vapor the lower its boiling point. For instance at approximately 29 inHg. water will boil at about 76° F. So the more vacuum we can maintain, the better.
Moisture in the system can be handled by the desiccant in the drier, if not too much. But if too much...it will migrate to the TXV and Evaporator and freeze up (blocking your system). So let's just do it right the first time.
For best results you need:
1. Properly functioning components
2. A clean system (no contaminants such as air, moisture, stop leak, etc...)
3. Leak free components (compressor, lines, drier, evaporator, condenser). Refrigerant is a NON-Consumable, it can only escape via leaks or be compromised by contaminants.
4. Proper amount of Oil and Refrigerant.
So starting with a new or completely evacuated system is the easiest of all scenarios. We know how much of everything we need, we know (or should know) the condition of everything). It's partially filling or diagnosing a system that is hard. Not this.
thanks!
I got mine from @1972FJ55 , Rex locally. I don't have a part number for the three schrader valves, but the tool is a Santec #MT1035.
