Good job timmy. Thanks for sharing.
I've had some very difficult cone washer, where someone glued them in. It can be a trying job of pounding on a brass dowel.
This was day two of pounding on cone washers, found them glued in. I did more damage to my brass dowel, than I had in last 20 wheel bearing service.
I love this tool. Even glued in cone washer a breeze an fast.
If, wheel hub to hub flange face metal surface curled. Due to being pounded on, which should never be, I pound back and flat file. Making sure nothing prevents hub flange from seating flush on wheel hub.
Tip: Lay the tire/wheel face down on the ground. Set wheel hub/lugs in wheel. Works very well to hold the hub, as you break free rotor bolts and when you torque them back down.
I use the Slee spindle lube tool. To lube axle needle bearing & brass bushing. Provide no contamination in the axle in the spindle. Which contamination/water entry, happens a lot when grease cap reused. When I've not pull knuckle or FDS (AKA CV).
Axle needle bearing & bushing are required to be lubed every 30K miles, as are wheel bearings.
When knuckle off, I just pack with grease by hand.
FSM, states: hub flange (HF) nuts as non reusable. New HF nuts threads are sealed. If threads of HF nuts, not stretched/loose. I reuse them, with some blue on the threads. The 24ft-lbf torque, need not be reduced for the lubed threads. Since torque spec, takes into consideration already.
Snap ring should never be reused. They expand each time we install and removing. This result in loose fit, which damages snap ring and snap rings axle groove.
Loose snap ring ride on edge, and often pop off axle.
They also enlarge axle groove, pushing splines upward and round the axle groove. Then axle groove can not retain snap ring. Which will also result in hub flange, getting hung up, was we work to remove it from axle of FDS.
Setting new gap to under .20mm. Insure a few things. One being that FDS outer seal, pulls into knuckles rear seal as designed. To insure we don't get water entry passed good seals.
This was my first axle puller, just toss together with stuff lying around. I pull axle, to seattle grease where FDS butts to the brass bushing in back of knuckle. W Seattleing of grease, is so, a ture snap ring to hub flange gap can be measured.
Setting snap ring gap. Series 100 Toyota Land Cruiser 6 of 6
Used a "D" snap ring which is 2.4mm, factory stock is 2.2mm. Very important to settle grease at back of knuckle between axle brass bushing and front drive sh...www.youtube.com
Here's the axle puller I now use.
The 100 series has two size front brake pad shim kits. In 2003, 100 series were fitted with larger pistons, in the front calipers. Thus the two sizes of shim kits. The 03-up has wider clips on outer shim to fit the large pistons. When we put the 03-07 shim on 98-02 caliper, they're very tight. So tight a fit, we need to bend the clips. Just the opposite when 98-02 shims shims, placed on 03-07 calipers.
Tip for improved braking in the 89-02, install the 03-07 front calipers.
The shims tie the pads to pistons. The square edge, of piston seals. Binds and rolls/twist building tension, when we brake. As we release brakes/pedal, the piston seal returns to original shape, pulling piston/pads away from rotor. The single spring held on by the lower pin, pushing outward on pads. Is; anti rattle spring. Two is fine, but the one is all that's needed.
You really need both standard and deep if you're going to turn wrenches. There's lots of affordable socket sets on Amazon. I like Gear Wrench, but there's lots of others that are good and affordable.I recently did a full brake job on the rear, but pads only on the front, this video is by far the best for thorough walkthrough regarding front rotors, thank you very much!
From your experience, if I invest in a new set of sockets 10-24mm for basic maintenance, should I get shallow or deeps?
I used the fish scale on my 85 4runner that has 37" tires to set the wheel bearing and trunion bearing preloads and all good.very thorough thanks for posting!
my $.02 on the wheel bearing torque. Don't worry about fish scales and torque specs. While you have access to the bearing preload nut, mount the wheel and tire with a few lug nuts. Grab the tire at 12 and 6 o'clock and wiggle. Torque the nut until there is little to no play.
I've found the fish scale method isn't quite tight enough if you have oversized tires.
Yeah, I'm known, for being long-winded and detail oriented.Now that's a comment!
