Has anyone done a front bench seat conversion from the LHD FZJ? I’m really dying to do it but haven’t seen anyone else attempt or even really talk about it in much theoretical detail.
How have these Corbeau seats held up?Corbeau Sport black leather pre and post tuffy console swap mod. On modified corbeau double slider seat brackets. View attachment 1595277 View attachment 1595278 View attachment 1595279 View attachment 1595280
I don’t have them but I have sat in them. They suck… Seat cushion doesn’t extend far enough to support your legs. Quality feels meh and they aren’t even cheap. Imo save up for sclhlee mans or just find manual cloth 80 seats really not worth wasting your money on those.How have these Corbeau seats held up?
Did you ever get these working?They require a Volvo CAN bus signal to wake them up, then the onboard ECU's do the rest. Still working out the heat and ventilation functions, as well as the bolsters, etc.
I have all the seat movements working, but the heat and ventilation will require more effort. Need an interface or buttons to control, and the right LIN signals (sniffed from a Volvo with the same functions) to make it all work. Its on my list, but there are more fun/pressing things higher up on the priorities.Did you ever get these working?
Love these! I’m eyeing a pair of seats out of a 2020 XC90, they’re in great shape. I’ve only heard good things about Volvo’s seats. Not sure if S90 and XC90 share the same seat but these look similar to the ones im watching.Thought I would throw mine in here. Thanks to all for the inspiration. These are 2018 Volvo S90 Inscription trim seats. Heated, ventilated, leg extension, lumbar, etc, etc. Not sure I would recommend them due to amount of crap to make them work, but they are gorgeous and comfy. I loved them and made them work. They require a Volvo CAN bus signal to wake them up, then the onboard ECU's do the rest. Still working out the heat and ventilation functions, as well as the bolsters, etc. Used the planted brackets and added steel plates to extend them since the base of the Volvo seat is wider and longer.
Little update on this. Needed to move the passenger side Bottom Frame to Rails mounting holes 1.25 inches toward the center console.Corbeau Trailcats and the 80 series seat mounts.
Drivers side fit great. Holes lined up and the chair is able to slide/recline. Could be maybe a half an inch closer to the center console so the seatbelt can retract easier.
Passenger side is too close to the door and the floor mount will need modified to bring it a little closer to the center console. The mount needs to have the seat sitting at least and inch (maybe more, tbd when I get in there to mod it) closer to the center console.
View attachment 4121627View attachment 4121628
Only if the office chair went in the 80 . . .does this count as a seat swap?View attachment 4171845
