First I'll need to set-up a windows XP 32bit notebook and dedicate it to garage I suppose. Then hopefully I can get my MINI-VCI cable working. For now just trying to get more knowledgeable with ABS and easy concerns about safety of driving home.
I would agree if any wheel sensor not working properly system would shut down ABS, but not brakes. So this is good guess.
Pedal & brakes felt normal so booster pump working. But I'll need to test to see pumps runs 30 to 40 sec (key on, booster empty) and stops as designed after pumping pedal more than 40 times (key off) to empty booster, for quick field test before driving.
Didn't think about fuse or relay, I'll give that a quick look before I drive. Be nice if this is all it is.
I need a 98-99 LX FSM. All I've got is 00 LX, 01 & 04 LC FSM. If IIRC 00 is when TRAC & VSC was added so FSM testing procedures my be different.
