COMEUP Winch Seal Gen2 20rs
COMEUP
Supporting Vendor
Our newest addition to the Seal Gen2 winch lineup. 20,000lb winch!
Description
  • 12V DC severe duty winch rated at 20,000 lbs.
  • Heavy duty series wound motor delivers superior torque output and faster line speed.
  • Motor equipped with a protective thermal sensor
  • Clockable ergonomic clutch T-handle.
  • Hardened steel, 3-stage planetary gear set for durable and reliable operation.
  • Both built-in digital two way wireless remote control and wired waterproof remote control.
  • 12 strand construction synthetic rope coated to improve abrasion resistance.
  • Tough aluminum die cast housings withstand strength of 2.0 x rated load of winch.
  • Patented mechanical cone brake safely holds the full load
  • Meets international standards of CE Machinery Directive 2006/42/CE, CE Electromagnetic Compatibility Directive 2004/108/EC, and SAE J706 Surface Vehicle standard 2003-08 rev.
Specs
Rated Line Pull20,000 lb single line
Motor5,220 w / 7.0 hp 12V series wound
Gear Ratio3-stage planetary 343:1
Clutch (freespooling)Rotating ring gear
Brake (outside the drum)Automatic, full load CBS (Cone Brake Structure)
Winch ConstructionAluminum die cast housings with steel drum
Drum Size3.5" x 8"L
ControlBoth built-in digital signal two way wireless remote control and waterproof wired remote with thermometric indicator LED w/ 17’ (5 m) cord
Rope TypeSynthetic rope
Rope Size9/16" x 55'
Mounting Bolt Pattern10" x 4.5" (254 x 114 mm), 10" x 6.5" (254 x 165 mm)
Winch Weight109.3 lb
Gross Weight140.2 lb
WarrantyLimited lifetime warranty for mechanical components, three (3) year warranty for electrical components
Box Dimensions29.1" x 10.6" x 19.5"
That thing is a Beast!
Hmmm, wonder if I could bolt that 7hp motor to my 8274 🤔
