Build Colonel Mustard Revival
Don’t you worry about bondo cracking?
Meh… not if it’s too thick.
I may grind this off and use the fiberglass reinforced stuff for the first coat when I do the real body work. Just wanted to see what progress looked like.
I also put a ton of 3M seam sealer on the exposed welds in the inside.
How to free hand a wheel arch
This one will be picture intensive, however, I think it shows how to easily form a wheel arch without using purchased panels, which probably won't fit anyway. A bit of sheet metal, and some welding is all you need. Some old beer case cardboard helps too for patterns I learned this from Fitzee Fabrication on youtube, there is a link in my previous posts. I also used this on the rear quarter panel that you already see. It worked so well, ill end up going back to the driver side and re working that wheel ach, while that side is OK, its not a good as what we have here.
K5HzydksHryYStxqTPEMQYrTGNJafV_KNtHl8ZcFhu2dfYaAlZL9L0IMjRK8bDQuvIaC357Q-wVgc5L0HvXL1Fns_woPacdYwHfXjguslcQEYOapqtsoUfRLLJY-120Lj2_RJkPRJTWVJ8rljEzvS_E
Here is what i started with, similar to the rest of the vehicle, not much left, although technically better than the passenger side
S8rACGz1KNGSS34SwxVlztRBOk9qxDuNXiI2qWW6Ixaa2q1E3QIS_45ioUHpuEjH-JHtr_DZL9bgARQ5m84OEjBG0aesR51U3aVPkXuXFW-8ubHLV4ZlbFae49vwRf6165-YwDmiA49ePcIgCioTayI
I cut out all the rust, then flanged and welded on some sheet metal that was at least 2 inches too long
E-GBuX2J7SKxg1NrEkCCO4pTfGAUMwFDpkx34pVldgbU_84F8F641KBQudeD54Ay81ha5cxEW4-GIYnur5rsnR6mRQ1EfRzMkAYE34dE-msI1ziNCzhQYG1U52GOclCM8d1q9vEmLxNsG4xs_qdwIw8
Then I mounted the door and used that to trim and form the edge to match the door cut out. This is where a body hammer and dolly works pretty well
yL6cECHeV9IpeD07xBlWOeMs63ji4mVoND7o9rdyLUI-2HcWlSfI3z0i08DbSGh3Yl-Gz6o_FVam1YR2sctt3uvdN9fprmbIHLO_4dXb78shB6t138ixhBWi9iOb44EHjhAK9lWPkzkIDpvEu4IUzy0
Hard to see, but a nice clean line here
EPrbaW4dBMEEtoAOhG_jv9lOOmFkhFNG51JqyKelhxKt360OG5cKagCggN7HzpB8ETEz05EKG8Pl6TMAVseg7mWhsRioLJEy4VCiCwy4iegxFtoZ3KkE9LWHW6ljqINqba_qC0i2XAYHT0ImK2q396o
Similar to the door flange we will call it, next step is to weld on another oversized piece, then trim down to size
HTfvv4Hi3L8lJA2dLncoR8aGArkW02Y102lV90OuNgCfCT1S8CCeXJXv7-hTpcj0rawhuTjR8EWPX6IOE1YPEtiRBL12Okc554CHBsg8gCX5alUuj7X75linE6834KyaC2X_cSQ91kceMFv1gxgE8TE
top side trimmed and door fit checked
zC2BvMUty37Q6Zi7mVPKnIV_gpcTMQqxSweSG2nBAQdIonkB-dYwJoNPhgv-qiXb0Q47R8pziFMeHXMJa4yB6kW50xBCzl6sL1Lqu5LZslkef33aHnN5qUz3aINBNvA1bAbvBhFKBYSHDX1TL02BU1M
Then do the same on the bottom
KyL7DBqIP8VQnHirYEDyWverKIvvXutnZhgxEQEKQp6hUYddCdO9XGwaKuAlVtz5pvxS8gqDc2XthsUCsqokwHWnBQ1LAakqVPS3oh4yHD8-LuBjv4rfhwY3BBr7kPUMqb3PIFSJf3PVKs2ECDLqaNk
And here you have it… you just made a wheel arch without much measuring, no need for a break, or a shrinker / stretcher, and you didn't need to buy a custom panel. Just take some patience and a lot of welding. Ill finish welding and grinding when I get the rest of the rocker panel replaced.
If there are any questions let me know. This technique can be used in lots of circumstances to eliminate the need to use a break and other complex tools to get fancy shapes. In the end I think it works just about as well, and takes less time
Im back! At least for about 3 months, completed an entire owners suite in my house with a full bath and walk in closet. Also finished siding the house and replacing a few more windows, along with all the facia, soffits, and gutters, was a ton of work so now I have the summer off to continue the restoration of the rustiest 60 ever.
The driver side rocker was not near as bad as the passenger side, but still had some challenges. I was able to save about a 16 inch section of the existing inner rocker compared to about 6 inches on the other side. I also had some old repair work to contend with. Welded up the floorboards poorly about 8 years ago, and get to re-weld them up a little better, but still poorly again!.
AD_4nXcNE6CUKxG-sAPiMsndrhvcds8EC71jmTUJBKXREUDfJg4ji7FSfPA8SP5PhKCNXUy6fOFu_vTx6mt4AN-G10J7Ct-Vc4AjsNKX_RWzAAEU3iXNhS-RZ8yQpDjBee-3OYMjOntD1OIbtCv3_F89TknNL7ha
AD_4nXfWE4b7ho2hYGybNLJWOVzCUXQyxSmJQxu0CYZ2CxRmyly6muuzZ6Tg-D2GVkXuYIsriQ0I2Nmi4rXXRKdslgQ4Aol8XMhgSW8cYPQNsG0kMAC96_miJr0BPiVxv9SWoktxeFdkLTNMfLY6rYROtyOcuzM
What's left after cutting all the rust out, lots of holes to fill up
AD_4nXczYUMSKkJ4NnrMEG210h3gv4riAzrpcHSkE6v6JQ6zCRD--GoWwrbw1-Yw4-JKojf0_js_zJIYPMvDRmjCZ1jhrIQ05ndrD1zc7-gYBEbvcM_vmpCPWY6Ru1ab-Zo8xAouuGg9RWjR6uOPrXjAbA6W6Rg
AD_4nXfcH0F1euE8FR7ZyfupS-ELpFP5YyMFxldpGpYyTiUs-PnfQXm5SFN73WROkTw8Y3hPFr2CkBMayPTya6VJKW6Mmq9kPnZMpsF0vKirLXqcgDrTDdMJa7D3qDGHfMyC42o1C9680bJ9pBBTC1dzF-_Ybh8
A few days later, and i was able to piece together the inner rocker and floor boards, not exactly and perfect replica of what was removed, but should be close enough.
AD_4nXeKOVgbXLZodCGyo1SMOkcqurGACE90ZfodpMvNkz3cN9UrWH0TUtvvv-LcktOXULHhnI8dhHFX_3O711xxyE3cxSrXRtiqatAj3hKbr74GBzzvpZlghTryMdwbHarPQm0la0qdM1PFdfpSmLx-920w7J42
AD_4nXex9KrfDGBM_9S4moicaSXOujjUAb_tXnzZMbTExQsKHIMR32gAROG3Ntw3geVn9MeiSi-av2770AUN9WLAJmO8_esvzSdVggnLRhpey0hYfF7TeZyYPWu-9B6WLQGqgSW4ciYykb1p3O4ytcPesL_Yd85N
Luckily the front of the outer rocker was in good shape, so I welded it onto the reproduction panel. It was a poor fit and took a lot of bending and swearing to make it look close enough.
AD_4nXcJUSQ9cX0w8350jnyvgVW6Hlxdtvrm6TLPCB5dVEu-ko_th_uwGSqtlXHZhZ5VY5OmkPFkfbmJ9q6Do-BDc71Ex1T4XXH5zFIH0TZsqf-UIphHHMaynYuymCxD-kB9N2d4G6kukWbJ-KpTyUhGGN285y4
Here is the rocker panel clamped on, before i weld it in, ill need to install the doors and do a fit check, then weld in the bottom of the A and B pillers. There will be some issues with the fit up i think as its not going back together perfect.
AD_4nXcPZJMiQx9sNjGaXfJTfmiC7knWIIuLFTUDjl-ucE4xQ59aUE8ukPugDKg_XvTYNHFkPwBJ2UHoObfGFev07tUB9e7aaDx4Z9vOBNDmr0V_myfxXDEBQR1G5Wrgb_xRIg6WTZa5c9zcVZi0AfPleHv6U6oM
Going a bit faster than the other side, ill have to do a lot of re-work on the passenger side when i come back to it, but it will still turn out.
Thanks for reading, ill give another update in a few weeks
Thank god.
I was worried. Glad you are back, I have been thinking about this thread in the last few weeks in regard to my 62.
Keep us updated.
I actually have one side mostly complete.
Rocker, a pillar, b pillar and the wheel well are all welded in. Still have to sort out the support structure under the body, that will be next.
Lots of grinding and bondo will be needed to make it all blend in. Fairly happy with the results considering what I’m working with. I’ll need to re work some on the passenger side with what I learned here.
Just finished up the underside supper structure and seat belt bracket. Other than some extra grinding before paint the drivers side is done! Now back to the passenger side to re do some of the work I already did. And do everything all over again.
Did the best I could to make it looks semi original. Used 16 gauge for the floor support and 8 guage for the seat belt bracket. I will have to modify the seat belt hole a bit to make it work with the thicker bracket.
I won’t do another update for a few weeks, as it’s all the same stuff here. Probally do something when I get the frame finished up and body mounted. House work is calling so it may not be for a few months. I was pretty proud of myself for the A pillar here and well…. Probally only this group of people would be as well, my significant other didn’t seem to think it was as neat at i did. On the left is what was left, and well here is how it turned out. Can’t complain about that!
After an absolutely asinine amount of welding, grinding, scraping sanding and painting, I am about ready to stick the body on the frame again. Maybe one weekend away. After that I’ll be close to ground level to take care of the welding, seam sealing, grinding and painting on the roof, rain gutters and interior.
Ended up scraping all the underbody coating and repainting with black paint. Very not fun job. I also seam sealed everything I could that would not hold water in. If you see older posts there was a lot of sheet metal work to get to this point.
On the frame you will see Trail Tailors 80 series suspension conversion welded on the front. I also did a lot of welding on the frame to deal with some rust, overall it’s in ok shape. Treated and painted with rustoleum implement paint. Also have the Trail Tailors frame stiffener in the rear.
Anyway, I’ll spend another week or two on this until the next house project come us.
Body is back on the frame!!!! Pretty big moment for me here. I used some energy suspension universal body mounts and then made some spacers with some 3/16th polyethylene I cut with a hole saw to make up any height differences. Seemed to work ok. Saved a few dollars on the ridiculous project that will take forever to complete. I suppose it’s time to put the roof back on. Maybe a roll cage first???
Hey team, its been a bit, had a few more weeks to work on Colonel Mustard here, and made some big progress. Last we left off the body was on the frame, now we are moving on to suspension with 80 series axles and LS engine placement. Most of this has been covered elsewhere. A while back Eaton e lockers were acquired, front and rear diffs were rebuilt with new bearings, and elockers installed, surprised for how many miles were on these axles, how nice the bearings were, and the backlash was still in check. For now I left the stock gearing, will decide later if I need to re gear. This will mostly be a highway mile machine.
After the diffs were set up, the axles were rebuilt and painted, similar to 80 back in the day. On the rear axle, since it will stay leaf springs to make room for a bigger gas tank, most of the mounting tabs were removed and grinded smooth from new spring perch welding later. Axles were fully assembled then bolted in, all bearings and seals were either Timkin or Koyo, lots of grinding, sanding a prep was needed, used Rulseloum primer and implement paint. The Trail Tailor 80 front suspension setup worked perfectly, and everything bolted right up with zero drama 60 front coil conversion.
Axles are in, now time for the motor, transmission and T case. The motor was built several years ago, it's a LQ4 with a bunch of fanciness that should be fun in the long run (port and polished 799 heads, stage 2 cam, all forged internals).. NV4500 transmission and the stock transfer case. Need to be careful with the pre 1985 stuff as it's not as common when ordering rebuild kits. The NV4500 was purchased through Advance Adapters, as well as most of the conversion stuff. The T case was also rebuilt. Everything was bolted together before installing into the truck.
The first major issue was the clutch slave cylinder interfered with the headers, i found a write up from Doug and Well sorted, NV4500 bracket, and copied his setup. His LS swap write up is much better than mine, check it out. really good LS swap write up. The next problem was engine placement, also from Doug there is a mount setup the keeps the stock LS engine mounts. Turns out there are also from Well Sorted, Best engine mount setup. After I ordered, I also got a nice email explaining how to use them. These key off existing bolt locations and really put the motor where it should be, no thinking or figuring out where things should go. Well well worth it tht AA adapters I have will never get used, well not on this project. Next was the rear transmission bracket, it's not the best, but will work for now.
And there it is, suspension and engine in, next up in the next month is steering gear, brakes, twin stick, and setting up the pinion and spring perches on the rear axle. Then its back to the house, looking to sell next spring, so there may not be much progress for a while, we will see. If there are any questions on what I did let me know.
Twin sticks are in and the the rear spring perches welded on and bolted down on the 80 axles.
The twin stick install with the universal AA kit was a bit of a challenge. Needed to fabricoble another bracket to place the pivot point like the clutch slave cylinder. I’m not sure I super like the handle placement but it is what it is at this point. If I had to do it over again I’d bend the 4wd selector forward a bit and the high low selector back a bit. And I had to separate the case again to put a new selector rod in that will work with the heim joint. Not as
much fun when it’s under the truck.
For the axle, I actually made a mistake and welded it in an inch off somehow. I guess I was not paying attention to the tape measure. Either way it was not too bad to re weld and fix, now it looks way better the 80 axles are A bit wider so I may need to add flares at some point.
This will be the last update for a bit. Going to work on the house for a while. Maybe some small updates with engine management stuff. Still a long ways to go but the end is in sight.
