Is it possible to add a coil spring to the existing suspension on a 62 to stiffen it and add a little lift. I was thinking it looks like if you got the right size spring you could jack up the truck until the axle dropped all the way and squeeze one inbetween the top of the axle and bump stop thing on the frame. Just thinking
I bought two beefy add a leafs down in Mexico. They will give around a inch lift and the cost was around 80 bucks, so for 4 you can guess around 140-160. As far as the labor goes, you take off your spring and "add" it to your spring pack and there you go.
I put the add a leaf on mine in the rear, still need to do the front, It lifted the cruiser about 4inchs. But my springs where so wore out they where bottoming out the shocks. I had to weld in new shock mounts, they were broke from the shock bottoming out. Only took a couple of hours.
Do I need to know what kind of springs I have already or does it not matter. I assume I have the oem springs but I am not sure because I have an ome steering stabilizier. If I do need to know how can I tell
