For Sale CO: 1970 FJ40
Year
1970
  1. 40 Series
Monument, Colorado United States
Mileage
136256
Color
Green
  • Rust spots replaced with new metal. Needs minor feathering at seam welds to be perfect.
  • Under carriage rust proofed with Corroseal brushed primer and sprayed finish coats.
  • Toyota gear reduction starter. Huge upgrade over original.
  • All new brake system with new master cylinder, hard and soft lines. Brakes work great.
  • New OEM radiator, hoses, belts, t-stat and water pump.
  • Refurbished front and rear heaters, both work great.
  • New OEM fuel pump and filter.
  • Upgraded elephant horns.
  • New exhaust from manifold back.
  • Rebuilt Carb completed by Mark Algazy
  • Knuckle/hub rebuild with new seals and bearings - made in Japan.
  • New TRE's - made in Japan.
  • New Iron Man 2.5" lift with shocks.
  • Toyo M/T tires with less than 1000 miles on GM 16" with OEM hub caps retrofitted to fit.
  • Spector seat covers that are very well made.
  • New OEM front bumper and rear bumperettes.
  • New OEM brake lights, marker lights, turn signals and reverse lights.
  • Factory wiring has been sorted with Coolerman harness sections and everything works.
  • New OEM emblems are included but not installed.
  • Door weatherstripping included but not installed. Majority of weatherstripping needs to be replaced.
  • Cracked windshield. Drivers view is not impacted.
  • Engine smokes some at start-up but runs strong. 3 on the tree!
  • Vacuum 4WD systems works great.
  • Bin of extra misc parts included.
  • Clean Colorado Title in my name.
My plan was paint the new metal spots and hardtop with the factory Spring Green color and keep the original paint and patina as much as possible. Was going to replace the original grey seat covers with coral colored covers from Cruiser Corps, which would look awesome next to the Spring Green exterior color. Don't buy it if you're uncomfortable with people wanting to talk about it everywhere you go. $19,500
man what a great looking 40.
greatest color 40 ever made.
Nothing screams the American Southwest like seafoam green
Lean into it
