My slave cylinder leaks, and I believe that 9it got a little air in it and is now stuck. Hint: 3000 rpm's and only going 15 miles an hour in 4th. Will a rebuild kit for my slave be sufficient or will I need a whole new one?
There is a few different sizes and types so measuring is required when it's a PO mod. I'm using chev parts but if you can afford it the centerforce is one tough SOB.So you have a V8, you will need to measure the diameter of the clutch disc/plate, if you do not know exactly what you have. IIRC Chev has a couple different clutch assemblies that could be used...
