Searched here and did a bit of searching on the internet without a clear answer to my question.
This is my daughter's 84 4x4 Mini Pickup with (after low speed roll) 86 tub on it.
Essentially, the issue is that unless she floors the clutch pedal at a stop sign or light with the engine running she'll stall.
Now admittedly shes on the short side to start with. I have always pushed the clutch pedal to the wall to shift, myself. Just was taught that way. In her case, you have to get it pretty far down there to disengauge. Maybe less than an inch from the floorboard.
Maybe that's normal. I don't know. Our RAV4 is the same. But my FJ45 and 40 are not: they engage about 1/2 way through the pedal swing.
So, is that normal? How can I tell? How much movement must the slave pushrod push the release fork to get good disengagement?
I mean, it could be weak pressure plate springs, or it could be poor push rod movement. I think if I knew the proper swing of the end of the fork I could tell if it was less and make it an upstream problem rather than a downstream (weak springs) issue.
Assume no obvious leakage from either master or slave. I would think air in the line, or too little pedal height, not letting the cylinder to fully load before pressing down on the pedal. Right? But then I would have too little free play, right?
PS, the Slave push rod is nonadjustable in this setting.
How do I tell what I've got (I am not in Fort Collins until Memorial Day)?
Would the clutch pedal engagement height tell me anything? Is it too high or low? I think it's about an inch, but that's what the RAV4 has, much closer to the firewall than my FJ45 pedal???
