John,
It isn't the 9 LED, but I just check the website weird its not on their list.
Also it's not easy for me to answer your question basic on writing without showing you in real life
Okay for example, Compare a red LED to a red-filtered incandescent lamp. A red LED might be as much as 10 times more visible than the red-filtered incandescent lamp because the red filter reduces the incandescent's light output. Unlike an LED, which is a monochromatic light and doesn't need to be filtered, an incandescent emits a full-spectrum light and, therefore, requires a filtering system to produce light of a specific color.
And remember to run the LED you have to use load equalizer ( LED resistor )on the signals because there isn't enough current draw with led's as opposed to filament bulbs.Most autos give you a warning when your bulb blows because its not pulling enough current so the turn signals flash at an increased rate. When you put the load equalizer in (which is typically nothing more than a fancy encased resistor) it ends that problem.
Okay? And this is Mot thread we should apologize to him by compare LED vs regular bulb.
