Hi, I just have a few questions upon browsing the superbrightleds.com site and inputing my car:
1. If I plan to change all my bulbs + turn signals to LEDs, would I need the Flasher unit + Load Resistor? Or will just changing the Flasher unit or just load resistor suffice? I need even my front and side turn signals to be changed to LEDs
2. Generally, will placing LEDs into the stock halogen housings dampen/weaken the LED power? Im assuming since the housing was designed for Halogen, then LEDs might end up weaker than halogen lights.
3. IF LEDs can possibly be brighter even in a halogen housing, what kind of LED light spread degree should i get for my tail/break/signal lights? 360 degrees? 90? 45? 180?
4. I am also considering simply buying the DEPO LX450/LC80 Clear Style Tail Light housing unit with built in LEDs already. are these powerful LEDs or simple ones where you just see the dots clearly? If i do buy this, do i still need to buy a flasher unit / load resistor?
Thanks!
Thanks!
