The below article recently came up about the 2022 Silverado ZR2 “magically” shutting off 4wd mode while off-reading.
www.caranddriver.com
Curious if the author’s observations are how all awd systems work (ie including the LC200) or are they overly generalized?
Fwiw, I’ve never had my LC200 decide to disengage the center diff on its own accord…
“So when you're in high-range four-wheel drive, or low range, the front and rear axles aren't really physically locked together. They have that clutch in there, doing its best, but with too much load it can tap out…
““In trucks with a part-time transfer case, the front and rear axles are physically locked”
The Chevrolet Silverado ZR2 and the Mystery of '4WD Off'
The ZR2 is a mean trail machine, but I accidentally discovered its weak point.
