Ok guys,
I bought an h55f and I need to swap shafts. It has a fine spline long input shaft and I need the short one. I have a short one and thought it would be a simple swap, but now I need some help. I looked at my FSM for my fj60 and it shows how to remove it for a 4 speed so that is what I did. I removed the front bearing cover and then pulled the lower bearing and then it shows using a slide hammer type puller on the input shaft. I did this and the shaft came out about half the distance and bound up on the bottom shaft.
This tranny is still on my transfer case and I was hoping to not have to split the case and pull everything apart from the rear. Any of you h55f guys care to give me the procedure for this?
By the way, I did do an extensive search for this before posting.
Thanks,
Don
IMG]http://i457.photobucket.com/albums/qq294/engraversart/inputshaft.jpg[/IMG]
Thanks,
Don
