Center arm swap
Kansastitty
I just did the minitruck PS conversion and I'm also swapping my old pin style center arm for a rebuilt tapered centerarm. Do I need to change the length of the rod that goes from the center arm to the passenger side hub? Or at least severely adjust it? I don't have the centerarm mounted yet, as there is a big difference in the way they are mounted. ??? ???
Poser
Oh...Durka Durka Durka.
Supporting Vendor
MN
If at all, you will have to shorten the drag link, but not a whole lot. The mounting of the center pivot is slightly different, but is not that big of a deal...
This piece you are refering to is a drag link. The tie rod 'ties' the two front tires together...just fyi..
Sounds like good improvments, you will love the PS.
Good luck!
-Steve
