FAQ CEL Codes List--(1997 FZJ)
OGBeno
23303-56040
Moderator
GOLD Star
Patagonia, Arizona, USA
Since I've seen lots of CEL codes pop-up here and people either cannot get to Autozone, don't have an OBD-II reader, or an FSM, I've decided to list all of the CEL codes from a 1997 FZJ80 for reference purposes.
Maybe this can be put into the FAQ's for others to use.
Hope this is of use to people. In terms of what you need to do for resolving said P0 situation, you will need to reference the P0 to the correct FSM page that correspondes to the meter readings for diagnosis.
If anyone wants to add to this list, please feel free to. These are taken directly from the updated TIS website with updated FSM diagnostics.
BTW: Just got my first CEL code--135. Not going to worry about it now as I am going to a custom exhaust soon and will reintegrate new O2 sensors at that time.
Best regards.
-onur
Akron, OH
___________________________________________________________________
P0100: Mass Air Flow Circuit Malfunction: Trouble Areas: open or shot in mass air flow meter circuit; mass air flow meter; ECM
P0101: Mass Air Flow Circuit Range/Performance Problem: Trouble Areas: Mass air flow meter
P0110: Inside air temperature circuit malfunction: Trouble Areas: Open or short in intake air temp. sensor circuit; Intake air temp. sensor; ECM.
P0115: Engine Coolant Temp. Circuit Malfunction: Trouble Areas: Open or shot in engine coolant temp. sensor circuit; Engine coolant temp. sensor; ECM
P0116: Engine Coolant Temp. Circuit Range/Performance Problem: Trouble Areas: Engine coolant temp. sensor; Cooling system.
P0120: Throttle/Pedal Position sensor/Switch "A" circuit Malfunction: Trouble Areas: Open or short in throttle position sensor circuit; throttle position sensor; ECM.
P0121: Throttle/Pedal Position sensor/switch "A" circuit range/performance problem: Trouble Areas: Throttle position sensor
P0125: Insufficient Collant temp. for Closed Loop fuel control: Trouble Areas: Open or short in heated oxygen sensor circuit; heated oxygen sensor.
P0130: Heated Oxygen sensor circuit malfunction (bank 1 Sensor 1): Trouble Areas: heated O2 sensor; fuel trim malfunction.
P0133: Heated Oxygen Sensor circuit Slow response (Bank 1 Sensor 1): Trouble Areas: heated O2 sensor.
P0135: Heated O2 Sensor Heater Circuit malfunction (Bank 1 Sensor 1): Trouble Areas: Open or short in heater circuit of heated O2 sensor; heated O2 sensor heater; ECM.
P0136: Heated O2 sensor circuit malfunction (Bank 1 Sensor 2): Trouble Areas: heated O2 sensor.
P0141: Heated O2 Sensor heater circuit malfunction (Bank 1 Sensor 2): Trouble Areas: Same as P0135.
P0171: System too Lean (Fuel Trim): Trouble Areas: air intake (hose loose); fule line pressure--leak; injector blockage; heated O2 sensor malfunction; mass air flow meter; engine coolant temp. sensor.
P0172: System too rich (Fuel trim): Trouble Areas: fule line pressure; injector leak--blockage; heated O2 sensor malfunction; mass air flow meter; engine coolant temp. sensor.
P0300: Random/mulitple Cylinder misfire detected:
P0301: Misfire detected:
P0302-306: Cylinders 1-6:
Trouble Areas: Ignition system; injector; fuel line pressure; EGR; compression pressure; valve clearance not to specification; valve timing; mass air flow meter; engine coolant temp. sensor.
P0325: Knock sensor 1 circuit malfunction: Trouble Areas: Open or short in knock sensor 1 circuit; knock sensor 1 (looseness); ECM.
P0330: Knock sensor 2 circuit malfunction: Trouble Areas: Same as P0325 except at sensor 2
P0335: Crankshaft position sensor "A" circuit malfunction: Trouble Areas: open or short in crankshaft position sensor circuit for NE signal; crankshaft position sensor for NE signal; starter: ECM.
P0340: Camshaft position sensor circuit malfunction: Trouble Areas: open or short in camshaft position sensor circuit; camshaft position sensor; ECM.
P0385: Crankshaft position sensor "B" circuit malfunction: Trouble areas: Same as P0335 except for the NE2 signals are effected.
P0401:
EGR flow insufficient detected: Trouble Areas: EGR valve stuck closed; short in VSV circuit for EGR; open in EGR gas temp. sensor circuit; EGR hose disconnected; ECM.
P0402: EGR Flow excessive detected: Trouble Areas: EGR valve stuck open; EGR VSV open malfunction; open in VSV circuit for EGR; short in EGR gas temp. sensor circuit; ECM.
P0420: Catalyst system efficiency below threshold: Trouble Areas: Three-way catalytic convertor; open or short in heated O2 sensor circuit; heated O2 sensor.
P0500: Vehicle Speed Sensor Malfunction: Trouble Areas: Combinatoin meter; open or short in speed sensor circuit; ECM; vehicle speed sensor.
P0505:
Idle Control System Malfunction: Trouble Areas: IAC valve is stuck or closed; open or short in IAC Valve circuit; open or short in A/C signal circuit; air intake (hose loose)
P0510: Closed Throttle Position switch malfunction: Trouble Areas: open in closed throttle position switch circuit; closed throttle position switch; ECM.
P1300: Igniter Circuit Malfunction: Trouble Areas: open or short in IGF or IGT circuit from igniter to ECM; igniter; ECM.
P1335: Crankshaft position sensor circuit malfunction (during engine running): Trouble Areas: open or shot in crankshaft position sensor circuit for NE signal; crankshaft position sensor for NE signal; starter; ECM.
P1520: Stop light switch signal malfunction: Trouble Areas: short in stop light switch signal circuit; stop light switch; ECM.
P1600: ECM BATT malfunction: Trouble Areas: open in back up power source circuit; ECM.
P1605: Knock control CPU malfunction: Trouble Areas: ECM.
P1780: Park/Neutral position switch malfunction: Trouble Areas: short in park/neutral position switch circuit; park/neutral position switch; ECM.
PO755: Shift Solenoid B
Symptoms- Trans will not shift into overdrive when depressing OD button even though light goes off. When one attempts to engage OD it is still in 3rd gear. As you coast/cruise and let off of the throttle the RPM's go down to idle as if it isn't in gear.
There are 3 solenoids in the transmission that are available from CruiserDan that could be suspect. 2 of them are the same units (1) at $109 and the third one (3) is $181. 2 on the side and 1 on the back. The back one is a (1).
Update
Here is a way to decode your OBDII codes:
For those of us with 6 cylinder engines this should read:
P0300: Random/multiple cylinder misfire detected
P0301-306: Misfire detected Cylinders 1-6 eg P0301 = Cyl. #1 etc
(would also add - check main engine wiring harness for shorts/breaks. Trouble spots with harness around EGR near #6 cylinder and firewall entry to ECM. CEL can be flashing when multiple misfires occurring.)
Edited to add ... 300 series codes were corrected on my 1997 LX450 with a new CPS - crankshaft positioning sensor
Here's a few others that were missed in the original post (found in the AT section of the FSM):
P0710: Transmission Fluid Temperature Sensor Malifunction: Trouble Areas: open or short in ATF temperature sensor circuit; ATF temperature sensor; ECM.
P0750: Shift Solenoid "A" Malfunction: Trouble Areas: shift solenoid valve #1 is stuck or closed; valve body is blocked up or stuck.
P0753: Shift Solenoid "A" Electircal Malfunction: Trouble Areas: open or short in shift solenoid valve #1 circuit; shift solenoid valve #1; ECM.
P0755: Shift Solenoid "B" Malfunction: Trouble Areas: shift solenoid valve #2 is stuck or closed; valve body is blocked up or stuck.
P0758: Shift Solenoid "B" Electircal Malfunction: Trouble Areas: open or short in shift solenoid valve #2 circuit; shift solenoid valve #2; ECM.
P0770: Shift Solenoid "E" Malfunction: Trouble Areas: shift solenoid valve SL is stuck or closed; valve body is blocked up or stuck; lock up clutch.
P0773: Shift Solenoid "E" Electircal Malfunction: Trouble Areas: open or short in shift solenoid valve SL circuit; shift solenoid valve SL; ECM.
P1700: Vehicle Speed Sensor #2 circuit malfunction: Trouble Areas: Open or short in #2 vehicle speed sensor; #2 vehicle speed sensor; ECM
Also ADD to Trouble Areas - check the Crankshaft Positioning Sensor - CPS
I am a newbie, not new to Yotas but my first 80 Series, seeking suggestion for best code reader/scanner for my recently acquired 80 series ?? Thank you
Depends on how much you want to pay...I have a BAFX bluetooth OBDII reader that I use with TorquePro. It hasn't failed me yet. The Apple compatible version doesn't like my son's IPhone much. Doesn't bother me at all.
It depends upon what model year and engine
1997 , prefer stand alone unit, I don't need anything co-mingled with my phones or other devices
collated all above posts and edited for printing, so you have this out on the trail.
P0301-306: Cylinders 1-6:Misfire detected Cylinders 1-6 eg P0301 = Cyl. #1 etc Trouble Areas: Ignition system; injector; fuel line pressure; EGR; compression pressure; valve clearance not to specification; valve timing; mass air flow meter; engine coolant temp. sensor. (would also add - check main engine wiring harness for shorts/breaks. Trouble spots with harness around EGR near #6 cylinder and firewall entry to ECM. CEL can be flashing when multiple misfires occurring.) CPS - crankshaft positioning sensor. Trouble Areas: Ignition system; injector; fuel line pressure; EGR; compression pressure; valve clearance not to specification; valve timing; mass air flow meter; engine coolant temp. sensor.
P0401: EGR flow insufficient detected: Trouble Areas: EGR valve stuck closed; short in VSV circuit for EGR; open in EGR gas temp. sensor circuit; EGR hose disconnected; ECM.
P0505: Idle Control System Malfunction: Trouble Areas: IAC valve is stuck or closed; open or short in IAC Valve circuit; open or short in A/C signal circuit; air intake (hose loose)
P0755: Shift Solenoid "B" Malfunction: Trouble Areas: shift solenoid valve #2 is stuck or closed; valve body is blocked up or stuck. PO755: Shift Solenoid B Symptoms- Trans will not shift into overdrive when depressing OD button even though light goes off. When one attempts to engage OD it is still in 3rd gear. As you coast/cruise and let off of the throttle the RPM's go down to idle as if it isn't in gear.There are 3 solenoids in the transmission 2 on the side and 1 on the back. The back one is a (1).
