CDL/ 4Lo indicator switches
Discussion in '100-Series Cruisers' started by LouisianaRubicon, Feb 9, 2018.
  1. LouisianaRubicon
    LouisianaRubicon
    325
    155
    Jun 5, 2014
    Louisiana & Kansas City
    2007 LX 470
    No dash lights come on after CDL engaged or shifting to 4Lo. Systems are working so it must be the switches on top on t-case.
    Do I need to replace all three? Does anyone have the part numbers?
  2. LouisianaRubicon
    LouisianaRubicon
    325
    155
    Jun 5, 2014
  3. Trunk Monkey
    Trunk Monkey Moderator
    8,851
    1,338
    Apr 27, 2003
    Salt Lake City
    Could be bulbs too, easy to check and cheaper than switches. Do you hear any relays clicking in the cab when you press the CDL button?
  4. LouisianaRubicon
    LouisianaRubicon
    325
    155
    Jun 5, 2014
    Yes, the relay in the dash clicks and it goes into 4hi.
  5. Trunk Monkey
    8,851
    1,338
    Apr 27, 2003
    Salt Lake City
    Have you verified it's not locked? Shift t-case into 4Lo, press CDL button, turn a circle, drive train should bind up/tires chirping. If the truck's never been used off-road before you, then it's possible the locker just needs some working to engage. Find a parking lot and drive a long S pattern to see if it will click in.
  6. LouisianaRubicon
    LouisianaRubicon
    325
    155
    Jun 5, 2014
    The systems work. Tires chirp/ drive line binds when shifted into 4LO or CDL switch engaged.
  7. Trunk Monkey
    8,851
    1,338
    Apr 27, 2003
    Salt Lake City
    Then it's probably a burned out bulb in the dash cluster.
  8. LouisianaRubicon
    LouisianaRubicon
    325
    155
    Jun 5, 2014
    I see. The dealer tried to sell me a new gauge cluster. I knew that couldn't be the case... Is there any way to verify its bulbs without taking the dash apart?
  9. Trunk Monkey
    8,851
    1,338
    Apr 27, 2003
    Salt Lake City
    Gauge cluster isn't too hard to remove, top of steering column plastic, black trim below cluster, couple of screws and two locating bolts.
  10. LouisianaRubicon
    LouisianaRubicon
    325
    155
    Jun 5, 2014
    Thanks, I'll look into bulbs first
  11. rjones
    rjones SILVER Star
    144
    178
    Sep 8, 2016
    Elk Grove, CA
    This is almost always the switch on the t-case in my research. There are lots of threads in the 100 section about this and I read them all. I was in the same boat as you with the CDL working and the dealer offering to replace the entire cluster but then I read up in here.
    I bought a switch and the longer/larger wrench that is supposed to help make it easier to swap out but never got around to it. After two days on a particularly bumpy/rocky trail with the CDL engaged most of the way BOOM the light came on and has worked ever since. Replacement switch sitting in my toolbox as I type.
    EDIT: 2006 LX for reference
    Good luck!
    rjones
    LouisianaRubicon likes this.
  12. LouisianaRubicon
    LouisianaRubicon
    325
    155
    Jun 5, 2014
    Thanks. Did you buy the oem switch?
  13. rjones
    rjones SILVER Star
    144
    178
    Sep 8, 2016
    Elk Grove, CA
  14. LouisianaRubicon
    LouisianaRubicon
    325
    155
    Jun 5, 2014
