These look the same as mine DID... After having the fitment and rubbing issue I went ahead and trimmed the brackets instead of my plastic. Just used a angle grinder and file. Probably could have done a little better job but lack of patience at the time. Hope the picture helps. one is passenger side under hood; other is drivers after install. No vibration issues or negative affect at this time. Still relatively strong.Does someone have a picture of just the brackets or can you confirm these are the same ones you got for fitment up to a 2015?
