Is this the CBI bracket?Here are some pics of the trimming. I probably need some more practice with my Dremel.
what type of bracket you used to mount your light bar ? do you have a link where i can purchase one fromI got around to installing CBI Ditch Light bracket and Rigid D-SS PRO Driving LEDs. Pretty happy with the install, the brackets work great. Although I did have to trim the windshield cowling slightly. Total install time took less than an hour. When driving trails or step, mountain snow covered driveways in winter at night to be able to see effectively to the side prior to turning is comforting.
The lights the way they are aimed, plus the design of the light, they fill the the space between the bumper mounted lights, the front edge of the 200 and the A Pillar. Plus add wider light coverage to the forward sides. I will find a open flat field at night to take a couple photos. Words really do not do justice to the result.
I agree, it worked like a charm and much better looking.When it comes to the CBI brackets i suggest that you guys use a heat gun to warm up the plastic a little and then close the hood so the bracket can mold the plastic. Instead of cutting into it
Any pics of this?I agree, it worked like a charm and much better looking.
I’ll get it to you this eveningAny pics of this?
Lots of options to mount to a roof rack.are there any rear brackets out there for the 2011 land cruiser to mount spot lights.?
i mean other than the roof rack .. I just have stock roof rackLots of options to mount to a roof rack.
You may find this is what you are afteri mean other than the roof rack .. I just have stock roof rack
forum.ih8mud.com
Wow! That is a lot less than I expected. I may need to get a set.
And you heat the plastic only or both plastic and bracket?
Same on the other side?
Just plastic. You want the brackets to be installed and then when heated slowly close the hood and it will mold perfectly.And you heat the plastic only or both plastic and bracket?
I’ll take a picture in the morning of what the brackets look like with the hood closed and how close it gets to the hoodCbi having spring sale. As good a reason as any to burn $60.
I figure that will be 1 less burger night with the family, runs about 60 bucks here at Whataburger.Cbi having spring sale. As good a reason as any to burn $60.
I've seen universal license plate brackets might work.Does anyone know if they make any brackets for rear spots and where can we install them on LC 200 series
