Caster question on stock AHC system (1 Viewer)
Moses lake
Main question: If I add high caster upper control arms will it pull my wheel towards the firewall or put my wheel farther forward?
I know with a lift these are needed, but i am planning on keeping my AHC system on stock height with updated and refreshed suspension to compliment the AHC.
Back ground check:
As of right now I have 35s on my stock 06 LX470 a buddy and I did the pinch weld cut down and also put it on a Hunter machine and found my cast is off but a decent amount and also because of this my wheels are rubbing on the firewall on one side and the washer revisor on the other side. The tires I have on the vehicle now are worn down and I know for sure that because of this discovery I need to get my suspension in order before continuing on to true 35s that are fresh out of the box.
More caster will pull the wheel towards the firewall. Note, only some aftermarket UCA's have the bracket for AHC.
