Toyota Claus! Thank you, Matt!i will include a complimentary set of 4 carb base nuts for you in your order for xmass
You been very helpful and appreciate the time and you answering my messages.
Thanks! I have one coming from ToyotaMatt.
On a fully-smogged 60, it's a bear getting to the two carb nuts closest to the valve cover. Whenever I encounter ones with any kind of washer or flange or curse-inducing 13mm nut it makes it that much harder to remove. I've always replaced with plain 12mm Toyo nuts and have never had one loosen, and they are much much easier to remove and replace with a slightly bent 12-point 12mm distributor wrench that's been clearanced a little for the tight casting.
Merry Christmas Cruiser people!
Michael Jackson is in your house?
