Ok, I'm a novice when it comes to carbs. I just installed my newly rebuilt carb and I can't get her to run. She will run fine if I prime it manually (dribbling gas directly into the carb), but dies as soon as I stop feeding her gas.
The rebuilder is experienced and has rebuilt Cruiser carbs before with no problem.
The throttle linkage appears to be working correctly
The choke is working correctly
The accelerator pump appears to be working correctly from what you can see externally.
My bubble shows fuel 1/2 way up
Fuel pump is working fine
The vacuum lines and idle solonoid are reconnected correctly
I have tried about every combination of throttle position, holding down, pumping, none, 1/2 way. The throttle "works" when adding gas manually, but it appears she's not getting gas on her own. I ran out of light and time before I tried looking directly in the carb to see if I could see gas entering. I did let her run for about 5 minutes adding gas manually.
Is there something simple I'm missing?
Is there a common mistake that could have happened during rebuild?
Did I do a search before posting this? (I'll answer that one, nope
