There are several other components in the "Carb Cooling Fan" circuit that might be responsible for the fan not functioning.
You might consider first temporarily grounding the circuit to see if the fan comes on. For instructions on how to run this test, see post #4 in this thread:
https://forum.ih8mud.com/threads/carb-fan-is-it-working.801129/#post-9274583
When you run that test, what you essentially are doing is controlling the ground of the circuit. Normally the temperature sensor near the exhaust manifold is responsible for grounding the circuit. When the temperature at the sensor is hot enough (i.e. the exhaust manifold is hot enough, so the air around the temperature sensor is hot enough), the electrical resistance inside the sensor material changes and allows the circuit to 'see' ground (when the ignition switch is turned off, too). When the circuit grounds, current flows through the circuit and the fan will kick on. There is a timer on the circuit too (see post #11 in the link above...it shows the "Carb Fan Computer"...which I believe is just the 'timer', but I'd have to double check the FSM...) which will interrupt the flow of current after a certain amount of time with the ignition in the 'off' position, regardless of the state of the temperature sensor...
So, if you run and pass the test, then all your components are working, except the temperature sensor. If you don't pass the test, then the temperature sensor is or isn't functional, but in addition, another one of the components is not functional...I'd pull and check the "Cooling Fan Relay" (see post #11)...check FSM for field test of the relay...
