I'll tack this onto an existing thread. My FJ62 carb fan works if you ground the sensor wire with the ign. on. Otherwise, I've never heard it work, even on blistering hot days.
I took the sensor out, and it showed infinite resistance. I heated it with a torch (gently) and the resistance started at 800 ohms and dropped to 200, before I chickened out and remove the torch. Is this normal? I don't know if the sensor is suppose to switch hard to zero ohms at a certain temperature, or if the resistance profile I saw (while heating) was normal. Does anyone know how a working sensor tests out? thanks!
I couldn't find the Electric Cooling Fan circuit in the wiring diagram from the "Landcruiser chassis-body-84-90 Repair Manual" (which includes the USA FJ62 model), but I found it on the FJ60 USA wiring diagram (see image below).
Don't know if it is the same.
Do you have an image of the FJ62 USA circuit?
Either way, your testing supports my interpretation of how the sensor should work when it is working properly and seems to support the logic of the mod whereby the wire that connects to the sensor is detached from the sensor and grounded (and as a result, the fan turns on after each shut down of the engine).
The reason why I think your tests show that the sensor is working correctly is that when the material inside the sensor is cold, the circuit is open (not grounded) and you read a resistance is very high - infinity - (open circuit).
And when you heat the material inside the sensor, the resistance begins to fall towards 0 and the circuit begins to close (in this case, when the circuit is closed, then it makes a ground - see wiring diagram).
Which means that by doing the mod, you are essentially mimicking the closing (grounding) of the circuit when the sensor is hot.
But if your sensor is working correctly, as your tests indicate that it is, and your circuit is set up as shown in the factory wiring diagram, and your electric cooling fan is still not working correctly, then there must be another problem in the circuit. Fuse? Relay??
