John McVicker
can't get freon in A/C comp. '85 22r carb Now: A/C compressor rebuild
Put a new schrader valve in the low port side to solve the problem of escaping freon which I described in an earlier post. But I now have a new A/C issue on my '85 Toy PU with 22r carb.
After a retrofit from r12 to r134 I can only get about 1/2 of a can of 134 into the compressor.
After this amount the high side gauge reads about 100 lbs. & it won't take anymore. AndI don't know why. Any thoughts on what the problem might be ?
I think I've done all the right things :
1) Installed the new ports from the retrofit kit.
2) Put in all new O rings, in the ports, hoses, etc.
3) Flushed out the system.
4) Installed a new dryer.
5) Vacuumed down to 29 for 45 minuets.
There is a leak because the vacuum does bleed off. But I am just trying to put a can of freon in and then another can w/leak testing dye to help find the leak. But I can't get enough in to do the leak test. Your thoughts are appreciated.
Thanks, John
Thanks, John
